Author Topic: I can't install it on the HDD [Solved]  (Read 5058 times)
Offline log762
« on: February 13, 2015, 12:50:06 pm »
Hello, I am trying to install peppermint 5 on my netbook but I am having some issues. I'v searched lot of things and still didn't find anything so that's why I'm here.
So my problem is:
- I have peppermintOS on my usb (I have also tried with a CD)
- When the installer starts I select the language, the updates...etc
- After all that it automatically selects that I want to install peppermint on the USB (with the cd also did the same but it said that there was no space on the CD)
- Inside peppermint i opened gparted to see if I see the disk with windows and I cant find it (I also tried sudo fdisk -l and nothing happens)
So what i have to do for replacing windows with peppermint?
Thanks
LINK TO THE SOLUTION:
« Last Edit: February 17, 2015, 03:28:09 am by log762 »
Re: I can't install it on the HDD
« Reply #1 on: February 13, 2015, 05:17:33 pm »
So what's the output from:
sudo fdisk -l?
Offline log762
« Reply #2 on: February 14, 2015, 05:03:42 am »
sudo fdisk -l?
There is no output, I write that and nothing happens it stays 3 seconds loading and then another line of the prompt appears for wrriting another instruction
« Reply #3 on: February 14, 2015, 06:11:12 am »
Hi log762, what is the make and model of your computer?  What version of Windows are you using?
Offline log762
« Reply #4 on: February 14, 2015, 12:26:57 pm »
Hello, its an acer aspire one kav60 running with windows xp
« Reply #5 on: February 14, 2015, 12:48:51 pm »
This is odd  :-\.  You say you are able to open GParted while you are using the Live Session.  From make and model of your machine and because you are running WinXP.  Your Windows partition should show up as an NTFS partition.
« Reply #6 on: February 14, 2015, 01:29:12 pm »
Can you post the output from:
inxi -F
Offline log762
« Reply #7 on: February 15, 2015, 08:33:55 am »
inxi -F
Here is the output:
I know, Is very strange :'(
When I open gparted it says: Invalid partition table - recursive partition on /dev/sr0 (when executing the live version on a CD)
Here is the output of fdisk -l and the gparted software:
Thanks for trying to help ;)
« Last Edit: February 17, 2015, 03:28:53 am by log762 »
rjm65
  • Guest
« Reply #8 on: February 15, 2015, 08:38:17 am »
From what I just seen on the inxi -F the drive is only 497 Megs, so something is wrong, there is no way windows xp would install on a drive that small...  Both linux and windows xp require at least 6 gigs or more space to install and function properly...   :)
Maybe it would be wise to post a screen shot of what you see when you run gparted from a live boot cd or usb, so we can determine what is going on.....
« Last Edit: February 15, 2015, 08:39:55 am by rjm65 »
Offline log762
« Reply #9 on: February 15, 2015, 08:40:34 am »
Its because is detecting only the CDRom, on the Cd i have that space left. The HDD of the netbook is 256 GB but it doesn't detect it
You have a screenshot of my gparted on my previous message: https://www.dropbox.com/s/igu9zq3bq2ucnxa/gparted.jpg?dl=0
rjm65
  • Guest
« Reply #10 on: February 15, 2015, 08:43:41 am »
Something is not right, does the xp partition on the hard drive still boot up?
It almost seems like the hard drive is not working at all.  :)
Offline log762
« Reply #11 on: February 15, 2015, 08:44:33 am »
Yes, I can use windows without any problem
rjm65
  • Guest
« Reply #12 on: February 15, 2015, 08:48:00 am »
For some reason it is not showing in gparted, which is something I have never come across on a machine as of yet, Hopefully pcnetspec has an idea what this may be...
Every machine I have ever installed linux on via a usb or cd when I run gparted before the install it always shows me the hard drive...  Sorry I was no help for you but mark should pop in shortly he always has ideas....  :)
« Reply #13 on: February 15, 2015, 09:48:22 am »
Linux isn't seeing your hard drive AT ALL  :-\
Any output from:
sudo lshw -C disk?
if not, you're going to have to run:
dmesg > ~/Desktop/dmesg.txtyou'll then find a file called dmesg.txt on the desktop .. host that file somewhere and provide a link to it in your next posting.
Offline log762
« Reply #14 on: February 15, 2015, 10:16:14 am »
Any output from:
sudo lshw -C disk?
Hello,
from lshw disk i get this:
peppermint@peppermint ~ $ sudo lshw -c disk
  *-cdrom
       description: DVD-RAM writer
       product: DVDRAM GT30L
       vendor: hp
       physical id: 0.0.0
       bus info: scsi@2:0.0.0
       logical name: /dev/cdrom
       logical name: /dev/sr0
       logical name: /cdrom
       version: mP04
       capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
       configuration: mount.fstype=iso9660 mount.options=ro,noatime state=mounted status=ready
     *-medium
          physical id: 0
          configuration: mount.fstype=iso9660 mount.options=ro,noatime signature=7fa3c5c0 state=mounted
and here is the .txt of dmesg:
« Last Edit: February 17, 2015, 03:29:23 am by log762 »
