Author Topic: (SOLVED) Trouble logging in to the new forum  (Read 2249 times)
Offline penrose1950
« on: April 07, 2014, 11:25:38 am »
hello i had trouble signing in to the new site as it did not recognize my username or password,i had to change my details and boy did i have trouble with the captcha thing,i had to try 5 times before i finally managed it,but all ok now.
thank you.
« Last Edit: April 08, 2014, 01:43:57 am by penrose1950 »
Offline kendall
  • Co-Founder
Re: Trouble logging in to the new forum
« Reply #1 on: April 07, 2014, 12:40:03 pm »
This is a new forum and the user credentials from the old forum do not work here. Thus everyone needs to register as a new user.
One of the downsides of captcha is that as bots get smarter, captchas often need to become more difficult in order to help weed them out. Unfortunately this often means that captchas are a frequent source of frustration for human users.
« Reply #2 on: April 07, 2014, 12:43:22 pm »
Hi penrose
If you were using the username & password from the old site you wont be able to log in, as you probably realised you need to re-register for this site, you'll also have to put up with the captchas a while longer, I think for the first 5 posts, after that you won't asked again
« Reply #3 on: April 07, 2014, 02:25:18 pm »
Key Captcha is now for registration and a single posting only :)
Effectively, once you get past first post moderation you shouldn't see it again.
Offline penrose1950
« Reply #4 on: April 08, 2014, 01:41:32 am »
ok thank you very much for all your replies,i have come back to Peppermint after using Mint 16 for a while,but i always come back here,keep up the good work.
thank you.
