Author Topic: (SOLVED) D-Link Wireless-N 150 Easy USB Adaptor: does not work on linux ?  (Read 9064 times)
Offline penrose1950
hello i bought the D-Link Wireless-N 150 Easy USB Adaptor but when i got it i found the driver is for windows or mac only,i tried it on peppermint 5 but it did not work so i have had to install windows 7 for the moment.
there is a driver for linux on the d-link website but when i downloaded it i could not see auto run or setup and did not know what to click on,any ideas please on how to get it working with peppermint 5 as my signal connection is about 68% without it and about 100% with windows 7.
thank you.
« Last Edit: January 22, 2015, 08:44:08 am by penrose1950 »
Re: D-Link Wireless-N 150 Easy USB Adaptor: does not work on linux ?
« Reply #1 on: January 09, 2015, 10:16:58 am »
With the adapter plugged in, post the output from:
lsusband
sudo lshw -C network
It might also be useful if you can post a link to the webpage on the D-Link website with the Linux driver
« Last Edit: January 09, 2015, 10:58:29 am by PCNetSpec »
Offline penrose1950
« Reply #2 on: January 10, 2015, 04:48:16 am »
lsusb
john@john-Aspire-5536 ~ $ sudo lshw -C network
« Last Edit: January 10, 2015, 05:37:07 am by AndyInMokum »
Offline penrose1950
« Reply #4 on: January 10, 2015, 05:39:19 am »
Hi penrose1950.  I see that the output you returned is very long.  In future, could you please encapsulate long outputs with the Sp Spoiler function.  This is located in the forum editor, just above the crying  :'( emoticon.  It makes it much easier for people to read and keeps things neat and tidy.  This time I've done this for you.  Thanks in advance ;).
Offline penrose1950
« Reply #5 on: January 10, 2015, 05:42:36 am »
sorry i did try to do that as i saw someone else being told,i tried to paste in between the sp but i will try again next time,thank you.
« Reply #6 on: January 10, 2015, 05:43:58 am »
No problem  ;D.
« Reply #7 on: January 10, 2015, 06:36:38 am »
OK, try this .. open  a terminal and run these commands in sequence:
sudo apt-get install linux-headers-generic build-essential dkmsthen:
mkdir ~/dlink-driverthen:
cd ~/dlink-driverthen:
wget http://github.com/lwfinger/rtl8188eu/archive/master.zipthen:
unzip master.zipthen
cd ~/dlink-driver/rtl8188eu-masterthen
makethen
sudo make installthen
sudo depmod -anow see if wireless springs to life when you run:
sudo modprobe 8188euif it does .. check it survives a reboot
Offline penrose1950
« Reply #8 on: January 10, 2015, 07:26:09 am »
udo modprobe 8188eu
modprobe: ERROR: could not insert '8188eu': Device or resource busy
« Reply #9 on: January 10, 2015, 07:50:46 am »
Try:
sudo modprobe -r r8188euthen
sudo modprobe 8188euif that works (or not) REBOOT .. then post the output from:
Offline penrose1950
« Reply #10 on: January 10, 2015, 08:08:55 am »
*-network
       product: NetLink BCM5784M Gigabit Ethernet PCIe
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: eth0
       version: 10
       serial: 00:1f:16:ab:91:6e
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm vpd msi pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.134 firmware=sb v2.19 latency=0 link=no multicast=yes port=twisted pair
       resources: irq:42 memory:f0300000-f030ffff
  *-network
       product: AR928X Wireless Network Adapter (PCI-Express)
       vendor: Qualcomm Atheros
       physical id: 0
       bus info: pci@0000:06:00.0
       logical name: wlan1
       version: 01
       serial: 00:24:2c:a2:8c:b0
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=ath9k driverversion=3.13.0-43-generic firmware=N/A ip=192.168.0.6 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
       resources: irq:17 memory:f0400000-f040ffff
  *-network
       physical id: 1
       bus info: usb@2:3
       logical name: wlan0
       serial: d8:fe:e3:56:99:93
       configuration: broadcast=yes driver=r8188eu multicast=yes wireless=unassociated
« Reply #11 on: January 10, 2015, 08:14:36 am »
OK, run
sudo modprobe 8188euthis time don't reboot .. just post the output from:
sudo lshw -C networkand tell me if wireless is working or not with the D-Link adapter
I'm a bit confused why you want a Nano in the first place, when you appear to have a working built in wireless adapter ?
« Last Edit: January 10, 2015, 08:34:59 am by PCNetSpec »
Offline penrose1950
« Reply #12 on: January 10, 2015, 08:36:43 am »
  *-network
       physical id: 0
       logical name: eth0
       version: 10
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
  *-network
       physical id: 0
       logical name: wlan1
       version: 01
       width: 64 bits
       clock: 33MHz
  *-network
       physical id: 1
       bus info: usb@2:3
       logical name: wlan0
Offline penrose1950
« Reply #13 on: January 10, 2015, 08:37:25 am »
i am getting 63%
« Reply #14 on: January 10, 2015, 09:00:58 am »
It still seems like the D-Link isn't associated, and you're still using the built in Atheros adapter ?
it also seems like you're still using the r8188eu driver, and not the 8188eu driver.
What happens when you run:
sudo modprobe 8188eu?
« Last Edit: January 10, 2015, 09:10:25 am by PCNetSpec »
