Author Topic: Received netbook with Ppmt on ! [SOLVED] ty.  (Read 27364 times)
Offline AuroraMagic
Re: Received netbook with Ppmt on !
« Reply #30 on: January 05, 2015, 04:44:38 pm »
ok
Single core intel celeron M cache 512 kb
Not too hopeful is it ! :(
I think I reported earlier that it is Ppmt v 1.98 from what I understood ....
Offline rjm65
« Reply #31 on: January 05, 2015, 04:48:56 pm »
1.98 geeze thats old. I wonder if it can handle peppermint 5, can you do the inxi -F like pcnetspec asked for earlier, and copy the info to a text file if need be, and put it on your usb stick, and then post info here from your windows machine...
« Last Edit: January 05, 2015, 04:50:56 pm by rjm65 »
Robert
Peppermint 9 User
Gateway Solo 9300 Pro
IBM T40
« Reply #32 on: January 05, 2015, 04:51:09 pm »
I need you to run:
inxi -F
then look (near thre top) for something like
Distro: Pepeprmint Five
or similar.
Ifr you can't find it .. run:
uname -r
and post the output back here
or the output from:
inxi -S
« Last Edit: January 05, 2015, 04:56:58 pm by PCNetSpec »
Offline AuroraMagic
« Reply #33 on: January 05, 2015, 04:54:43 pm »
ok :)
« Reply #34 on: January 05, 2015, 05:00:15 pm »
still awaiting the output from one of the above ??
Offline AuroraMagic
« Reply #35 on: January 05, 2015, 05:02:14 pm »
It says :
Kernal 2.6.32-24-generic i686 (32bit) Distro Peppermint
cpu single core Intel etc cahce 512 kb etc ...
No way of selecting the text and copy and paste ??? Nor any way of saving the file or finding a text editor ! :( So no chance of copying to drive ... not without help :) anyway!
Ran inxi -f and it brought back up the cpu Intel celeron M etc and a whole load of letters ! :)
Offline rjm65
« Reply #36 on: January 05, 2015, 05:04:27 pm »
can you take a picture of the screen after running inxi -F and post it somewhere where we can see like imgur.com?
Robert
Peppermint 9 User
IBM T40
Offline AuroraMagic
« Reply #37 on: January 05, 2015, 05:06:07 pm »
Yeah I can try ... :)
« Reply #38 on: January 05, 2015, 05:06:29 pm »
Forget the inxi -F output for now... I already have what I need...
OK, you're on a VERY early version of Peppermint .. either Peppermint One or Peppermint ICE or Peppermint Two
You really need to remove that and switch to Peppermint Three or Five.
But for now, do you want to get the wireless working ? .. and do you know your wireless key ?
« Last Edit: January 05, 2015, 05:16:27 pm by PCNetSpec »
Offline rjm65
« Reply #39 on: January 05, 2015, 05:09:13 pm »
I dug up specs on the eee900 mark here they are:
http://event.asus.com/eeepc/microsites/901_1000/en/specifications.html
Robert
Peppermint 9 User
IBM T40
« Reply #40 on: January 05, 2015, 05:11:33 pm »
@rjm65
I know the specs .. I was only trying to figure out the Peppermint version to see if it's worth going any further, or if it needs an upgrade.
kernel 2.6 was only used up until Peppermint 3 .. so whatever version it's running IS out of support and needs replacing.
That doesn't mean she can't have a look around the current version though .. until we get round to reinstalling
@AuroraMagic
See my last posting
« Last Edit: January 05, 2015, 05:18:03 pm by PCNetSpec »
Offline AuroraMagic
« Reply #41 on: January 05, 2015, 05:17:08 pm »
http://imgur.com/U0ZEOYe
hope this helps.
I reduced the res to help but maybe that wasn't necessary :)
« Reply #42 on: January 05, 2015, 05:18:59 pm »
(all of which are "end of life")
(don't publish your wireless key .. I just wanna know if you knw it or not)
« Last Edit: January 05, 2015, 05:21:25 pm by PCNetSpec »
Offline AuroraMagic
« Reply #43 on: January 05, 2015, 05:22:27 pm »
OK can't find the wireless facility ! It all seems hidden if you know what I mean!
So yeah if I can get it online that will be great! And obviously makes upgrading far easier !:)
Yes I know the wl key :D
Will Ppmt 5 work ok on such an old machine ?
It's v v kind of you all to help - I really appreciate it ! :D TY :D
« Reply #44 on: January 05, 2015, 05:29:52 pm »
Peppermint 5 WILL run on that netbook, but Peppermint 3 will probably be slightly quicker .. your call.
Peppermint 3 is supported till 2017
Peppermint 5 is supported till 2019
Anyway, wireless...
If you look bottom right of screen by the clock, you should see some icons .. one of them should be the NetworkManager.
If you normal left-click the NetworkManger Icon, you should see a list of detected wireless networks.
Click on YOUR network, and it should prompt you for "Authentication" .. this box wants your PEPPERMINT password, so enter it and click OK.
the next box will prompt for your WIRELESS key .. enter it and click OK.
Did it connect ?
« Last Edit: January 05, 2015, 05:33:42 pm by PCNetSpec »
