Author Topic: Received netbook with Ppmt on ! [SOLVED] ty.  (Read 27228 times)
Re: Received netbook with Ppmt on !
« Reply #195 on: January 08, 2015, 03:54:56 pm »
Probably not.
what is the exact message ?
Can you run these commands in sequence:
sudo apt-get updateten
sudo apt-get upgradethen
sudo apt-get dist-upgradethen REBOOT
Then try
menu > Internet > Dropbox
again, and tell me EXACTLY what happens when you try to run Dropbox
« Last Edit: January 08, 2015, 03:58:19 pm by PCNetSpec »
Offline AuroraMagic
« Reply #196 on: January 08, 2015, 03:57:17 pm »
"In order to use Dropbox, you must download the proprietary daemon."
(then 'don't show this again check box option & ok / cancel )
Do I need to reboot ?
« Reply #197 on: January 08, 2015, 03:58:56 pm »
Ah, I see .. when you get that dialog, select "OK" and it should automagically download and install the dropbox daemon. :)
Had me confused there for a second  .. it only does this the first time it's run.
« Last Edit: January 08, 2015, 04:04:28 pm by PCNetSpec »
Offline AuroraMagic
« Reply #198 on: January 08, 2015, 04:04:16 pm »
I guess I can be a 'bit too literal'!! Sry ! Yep that's working! TY again! :D
« Reply #199 on: January 08, 2015, 04:07:51 pm »
Or at my age I'm too easily confusticated  :-\
« Reply #200 on: January 08, 2015, 04:16:58 pm »
Okey dokey, as it's generally good forum practice to have a single question (with a well defined subject line) per topic, I think it best if we now close this topic.
From now on can you please post a new topic (with an explanatory subject line) per question.
It makes it easier for people who may have the same question to find an answer .. one question per topic also makes it easy to mark a topic as (SOLVED) if a solution is found .. again making it easy for people searching for a working answer.
TIA :)
« Last Edit: January 08, 2015, 04:20:05 pm by PCNetSpec »
Offline AuroraMagic
« Reply #201 on: January 08, 2015, 05:01:24 pm »
Yeah sure.
I was wondering as I am now well off-topic!
Thank you again for all your help! Solved perfectly & thanks to you all! :)
A wonderful introduction to Peppermint! :D Thank you. :)
What a change from the Windows nightmares!
Re: Received netbook with Ppmt on ! [SOLVED] ty.
« Reply #202 on: January 08, 2015, 05:26:18 pm »
You're more than welcome :)
