Author Topic: Received netbook with Ppmt on ! [SOLVED] ty.  (Read 25742 times)
Offline AuroraMagic
Re: Received netbook with Ppmt on !
« Reply #15 on: January 05, 2015, 03:37:49 pm »
OK yes I have a 16Gb flash drive.
Sorry that I kept disappearing - dinner and trying to find an important letter! (from Sheriffs as they are messing up trying to get money back from a shyster who took money then never gave me a car I paid for !) Anyway got the letter now!
I also have a horrid cold thing! sniffle ! :)
OK yes i have both at my fingertips ... :)
I can also use a big spare external drive that I have (in case the 16Gb isn't big enough).
I see that it's recommended that I use the chksum but do I really need to ? :D
OK ready when you are ! :D TY v v v much! :)
Oh I'm on my Dell whiz laptop so it ought to make life 'easy' :D hehehehe
« Reply #16 on: January 05, 2015, 03:49:35 pm »
Let's try one more time to reset the password, but slightly differently this time
Turn ON your netbook, and as soon as your BIOS POST screen disappears, press the SHIFT key and hold it, until you are presented with the GRUB menu .. SIMILAR to this:
(you won't have long to hit the shift key, and the timing can be a little awkward, so it may even be easier to hit AND HOLD the Shift key DURING the BIOS POST .. ie. immediately after turning on your PC)
Select the 'default' kernel (usually the top one), and rather than pressing enter, press E to edit.
You will be presented with a screen SIMILAR to this:
Press DOWN ARROW until you get to the line that starts with:
linux /boot
and press the END key to position the cursor at the end of the that line... it *usually* ends with “quiet splash”.
enter a space, then init=/bin/bash
so  the line now ends with quiet splash init=/bin/bash
Now hit Ctrl+X to boot.
You should now end up at a # prompt.
Now run:
mount -o rw,remount /and hit enter
then run:
ls /home(for clarity that;s LS /HOME but it MUST be all lower case)
That should return the username
then run:
passwd username(replacing username with the username you found earlier)
You should be prompted to "Enter new UNIX password" .. enter your new password (remembering nothing will be echoed to screen not even ******, but it IS going in) and hit enter.
You'll be prompted to "Re-enter new UNIX password .. enter if again, and hit enter
You should be informed that the password was successfully changed.
Now hit Ctrl+Alt+Del to reboot.
then use the username you discovered and the password you just set to login
If anything doesn't work as I explained it, STOP and yell me where you got to, and what the error is
« Last Edit: January 05, 2015, 04:06:44 pm by PCNetSpec »
Offline AuroraMagic
« Reply #17 on: January 05, 2015, 03:58:49 pm »
working on it! ...
« Reply #18 on: January 05, 2015, 04:02:39 pm »
Cool :)
Let me know if you have any problems, or are unclear on some point.
Offline AuroraMagic
« Reply #19 on: January 05, 2015, 04:06:16 pm »
ok got as far as -o (o not zero I assume although now tried all options possible) rw,remount
upon enter it says :
-o: command not found
« Last Edit: January 05, 2015, 04:08:41 pm by AuroraMagic »
« Reply #20 on: January 05, 2015, 04:08:09 pm »
yes it's a lower case o not a zero
for clarity
There are 3 spaces and one comma in that command
Also be aware, if that command works it will NOT return any output, it will just leave you back at an # prompt .. if it doesn't work it will throw up an error like before
« Last Edit: January 05, 2015, 04:12:40 pm by PCNetSpec »
Offline AuroraMagic
« Reply #21 on: January 05, 2015, 04:12:17 pm »
ahha ok sorry ! ooops D'O'h !
I'm an animator not a programmer ! :D
Anyway tried that and it's telling me a whole load about mount and command that I might enter but no un or anything like it is visible! :(
« Reply #22 on: January 05, 2015, 04:14:13 pm »
try again
Also be aware, if that command works it will NOT return any output, it will just leave you back at an # prompt .. if it doesn't work it will throw up an error like before.
Offline AuroraMagic
« Reply #23 on: January 05, 2015, 04:15:56 pm »
Ahha tried the ls /home and it's come back in blue with :
bobo savs
? odd un but do you think that is all a genuine un ?
« Reply #24 on: January 05, 2015, 04:19:55 pm »
that means there are 2 accounts on this PC
If the earlier mount command worked...
run:
passwd bobo
and change that ones password
then run:
passwd savs
and change that ones password to the same password you used for the bobo account
tell me when done, or if you get any errors
Offline AuroraMagic
« Reply #25 on: January 05, 2015, 04:24:42 pm »
Yeeeeeahhhh ! :) Done it ! Wooopeee! :)
TY v v v much ! I know I need a LOT of patience ! :D  Still I'm sure it's worth it for the laughter I created ! :D
(my late fella being a whiz electronics puta software and hardware chap - had me beta test stuff cos I just think differently! ) :D
Right both now have new pw so I will try and restart ?
How do I get back to the main scrn pls ?
« Reply #26 on: January 05, 2015, 04:25:58 pm »
Hitting Ctrl+Alt+Del (at the same time) should reboot the PC
« Last Edit: January 05, 2015, 04:28:55 pm by PCNetSpec »
Offline AuroraMagic
« Reply #27 on: January 05, 2015, 04:29:20 pm »
ok did the c alt del - found it thanks ... logged in! :D
It's worried about battery power but it's running on mains so fair enough!
Is there a way to swtich users within the system pls ?
Can you run win programs on Ppmt ?
Offline AuroraMagic
« Reply #28 on: January 05, 2015, 04:32:21 pm »
Ahha sorry found the logout bit ! TY v much for your help ! :)
Is it possible to change the un ?
(dare I ask!)  :-\
So what can I add in this OS pls ?
It has firefox and need to run it online  ... :)
« Reply #29 on: January 05, 2015, 04:35:23 pm »
You can switch users by going to
menu > Logout > Logout (button)
Then logging back on as the other user.
Windows apps .. no not reaally, SOME can be made to work but it's a royal pain and not worth the effort
An option is to run Windows inside a virtual machine, but I doubt if youur netbook will really be powerful enough.
Can we get some info about your system please .. I have a nasty feeling you may be running an old outdated version of Peppermint
Can you open a terminal
menu > Accessories > Terminal
then run:
inxi -Fand post the output back here .. just copy and paste it
be aware Linux commands ARE case sensitive, so that's a capital F in
inxi -F
I'll answer your other questions in a bit
« Last Edit: January 05, 2015, 04:38:09 pm by PCNetSpec »
