Author Topic: XBMC, now Kodi, crashes at video [SOLVED]  (Read 13508 times)
Offline winnipeg305
  • Peppermint version(s): 5
« on: January 03, 2015, 02:04:45 pm »
Here's the log. Any idea how I can correct this?
« Last Edit: January 03, 2015, 07:49:10 pm by winnipeg305 »
Re: XBMC, now Kodi, crashes at video
« Reply #1 on: January 03, 2015, 04:54:56 pm »
Try disabling VDPAU in the Video Playback settings (XBMC)
If that makes no difference, post the output from:
sudo lshw -C display
« Last Edit: January 03, 2015, 04:56:33 pm by PCNetSpec »
Offline winnipeg305
« Reply #2 on: January 03, 2015, 07:48:26 pm »
Turns out Google Earth wouldn't load either and the problem was the video card. Upgraded and all good now.
Thanks for your reply.
I'm new to Linux but I'm learning.
Re: XBMC, now Kodi, crashes at video [SOLVED]
« Reply #3 on: January 03, 2015, 08:58:47 pm »
Hi winnipeg305, well done figuring this out  ;).  In addition to your upgrade, have you also run a dist-upgrade? This intelligently handles changing dependencies with new versions of packages.
apt dist-upgrade -yIt is recommended that you reboot your machine after running a dist-upgrade, as there maybe kernel updates.  Thanks for marking the topic as [Solved]  ;).
Offline winnipeg305
« Reply #4 on: January 26, 2015, 06:15:35 am »
Thanks very much for this. There were updates and they are now installed. :)
