Author Topic: Synaptic Package Manager Using Application Launch Bar (SOLVED)  (Read 3543 times)
« on: January 02, 2015, 07:06:30 pm »
Hello Team Peppermint,
This a simple report:
When I try to launch our Synaptic Package Manager using our Application Launch Bar, I'm notified with this message:  Starting "Synaptic Package Manager" without administrative privileges   You will not be able to apply any changes, but you can still export the marked changes or create a download script for them.
Although I do not understand what it means by downloading script, I do know what it means when it says I will not be able to apply any changes.  Obviously, I placed this application in Peppermint 5's Application Launch Bar so that I could apply some changes.
I consider this to be a bug within Peppermint 5, and I thought I should notify Team Peppermint about this oddity.
Thank you,
perknh
« Last Edit: January 03, 2015, 04:16:37 am by perknh »
How did you add the Synaptic Package Manager icon to the Application Launcher Bar lxpanel applet ?
Because I just tried it and it worked flaw;essly from my Application Launcher Bar lxpanel applet.
it's as if your launcher is not running "synaptic-pkexec" as the command, but just "synaptic" which doesn't elevate the privileges (so it opens "read-only" as it doesn't have permission to make any system wide changes)
I'm guessing starting Synaptic from your Application Launcher Bar doesn't prompt for a password ?
« Last Edit: January 02, 2015, 07:51:26 pm by PCNetSpec »
Hi perknh, it worked flawlessly for me too.  When you open: Panel Preferences > Panel Applets > Application Launch Bar and edit.  Do you have two Synaptic Package Managers listed?  If you do, click on the upper one.  You will see displayed in the bottom margin: Exec = synaptic.  Click on the bottom one and displayed in the bottom margin is: Exec = synaptic-pkexec.  This is the one you need to use as it will present you with the password login box.  Remember, Synaptic requires elevated, (sudo) privileges to function.  I hope this helps - oh yes, Happy New Year mate  ;)!!
« Reply #3 on: January 03, 2015, 04:14:28 am »
Well, thank you, PCNetSpec, and AndyInMokum!
Yes, I do have two Synaptic Package Managers listed, and, yes, I've been using the top one -- thinking the repeat listing was minor bug too.  I can see I was wrong about that!  ::)
I added the Application Launch Bar using the Add/Remove Panel Items command for the lower panel.  I then added the Application Launch Bar, which initially gives me an empty space to the right of the End Session button.  I then move this empty application to the left, near my Menu button.  I then begin populating the space with my most commonly used tools.  Adding the lower Synaptic Package Manager to my Application Launch Bar has given me a working Synaptic Package Manager and has solved this problem for me -- so there is no actual bug here.  :)
Thank you both very much, and best wishes for the New Year to all at Peppermint forum too!
perknh
« Last Edit: January 03, 2015, 04:18:18 am by perknh »
Re: Synaptic Package Manager Using Application Launch Bar (SOLVED)
« Reply #4 on: January 03, 2015, 04:42:24 am »
Great to know its now working for you  ;).
« Reply #5 on: January 03, 2015, 05:45:36 am »
Thank you, AndyInMokum  ;)
Yes, Application Launch Bar Settings did the old double entry trick on me.  Pick the top entry saying Synaptic Package Manager and you lose, but pick the bottom entry saying Synaptic Package Manager and you win!  ;D
Actually I now see what they are trying to do with the two entries.  A parent, or a supervisor, gets administrative privileges.  Whereas the kid, or the worker bee, gets to check off all he or she wants, but nothing more.  Mommy, daddy, or the boss, gets to make the final decision.
« Reply #6 on: January 03, 2015, 05:55:41 am »
Well spotted Andy .. I hadn't noticed there were two (nor had I noticed it tells you the Exec= line), I guess I just got lucky when I tried it :)
« Reply #7 on: January 03, 2015, 06:36:09 am »
Offline rjm65
« Reply #8 on: January 03, 2015, 06:49:21 am »
this happened to me on other distros when i changed their default DE over to LXDE...  I just had to edit the properties and add the command behind synaptic to get the pword box to open again...
Robert
Peppermint 9 User
Gateway Solo 9300 Pro
IBM T40
