Author Topic: how come some items in the repos or mint install are outdated?  (Read 2096 times)
Offline iamesperambient
  • a totally awesome dude
« on: January 01, 2015, 06:31:34 am »
i noticed some versions of apps/programs are a version or two behind via repos or mint update
would they automatically update or have they not been added? this is a general question not on a specific app.
thanks for any info!
http://iamesper.bandcamp.com
boring drone music from NJ
Offline nomko
  • Linux User
    • Easy tips for Linux
Re: how come some items in the repos or mint install are outdated?
« Reply #1 on: January 02, 2015, 10:37:18 am »
Hi,
Can you specify which applications are 1 or 2 versions behind?
ASUS P5KPL-AM*Intel Core2 Quad CPU Q8200*4 GiB ram*nVidia GeForce 9500GT*Realtek RTL8101/8102E*Optiarc DVD-RW AD-7200A*HDD:Samsung HD501LJ/HD103SI*Sitecom X5-N600 Router
My Linux website
« Reply #2 on: January 02, 2015, 12:12:06 pm »
ive noticed for instance guake is outdated the lastest version
came out and i don't see it in mint install for the newest version
not a huge deal but something i noticed in general.
« Reply #3 on: January 02, 2015, 01:56:09 pm »
Packages are updated in the Ubuntu repos if and when they can be tested as fully working/compatible/clean and then packaged.
Not every third party package will get ANY updates .. Between OS releases they tend to update the big stuff like web browsers and flashplayers, etc. but lesser known/used software will either get updated when they get around to it or possibly not at all.
Third party software packages tend to be fairly recent when the OS is first released but obviously the authors may release newer versions .. Ubuntu/Peppermint don't have time to test ALL software as it's released then package it (and NOTHING makes it into the repos until it's tested and packaged (that's one of the things that makes Linux so secure), and as updates to the repos go out to EVERYONE automatically, stability is generally of a higher importance than having bleeding edge software  .. so if you want the very latest it's left up to you to step outside the repos, or wait for the next OS release which will have more recent versions out of the box.
« Last Edit: January 02, 2015, 01:57:47 pm by PCNetSpec »
« Reply #4 on: January 02, 2015, 02:11:32 pm »
ok thanks for the info :D
« Reply #5 on: January 02, 2015, 02:25:14 pm »
There may also be other reasons .. such a a third party software author relying on a recent library (or say xorg component) that hasn't or can't be backported to the earlier OS release.
(so the new third party software will never be able to run in 14.04 .. but will work in 14.10 as 14.10 has the newer libraries)
Kinda like software for Win7 that won't work in XP because XP doesn't have the correct DLL versions (and they can't be backported)
There's a lot of "reasons" .. but by far the most common is no time to check the implications for all other software in the default repos, and known stability/security takes precedence ;)
Third party authors are free to create a PPA and package their software themselves .. but NOTHING goes into the default repos until it's tested, checked and poked ;)
« Last Edit: January 02, 2015, 02:28:46 pm by PCNetSpec »
« Reply #6 on: January 02, 2015, 02:26:43 pm »
Offline nomko
  • Linux User
« Reply #7 on: January 02, 2015, 04:20:34 pm »
The explanation given by PCNetSpec is not really sufficient. PM and other Ubuntu-based distro's like Mint and Bodhi and Lubuntu/Xubuntu uses the following software repositories:
  • Main
  • Restricted
  • Universe
  • Multiverse
You can read more about them here: http://www.howtogeek.com/194247/whats-the-difference-between-main-restricted-universe-and-multiverse-on-ubuntu/.
This will also explain a bit better why some packages are "outdated" in the repository while there's a newer version available on the developers website.
My Linux website
« Reply #8 on: January 02, 2015, 06:41:52 pm »
Not the first time I've been called "insufficient"......
I guess there are times when a small assist from another member can help achieve a satisfactory response .. so many thanks for your additional input nomko ;)
« Last Edit: January 02, 2015, 07:39:29 pm by PCNetSpec »
« Reply #9 on: January 02, 2015, 10:28:50 pm »
  • Main
  • Restricted
  • Universe
  • Multiverse
thanks for the added info both equally helpful.
Offline nomko
  • Linux User
« Reply #10 on: January 03, 2015, 05:01:37 am »
No offence meant ofcourse ;)
My Linux website
