Author Topic: Asus eee netbook - 1024 * 768 resolution?  (Read 1566 times)
Offline JoeShmoe
  • Peppermint version(s): 5
« on: December 06, 2014, 08:11:20 am »
I have Peppermint 5 on an re-purposed Asus Eee netbook, standard resolution of 1024*600 - i know in Windows Intel updated the drivers to support 1024 *768 - has anyone got this to work in Peppermint and whats required?
Many tks
Re: Asus eee netbook - 1024 * 768 resolution?
« Reply #1 on: December 06, 2014, 09:03:50 am »
YES .. obviously you can't get it to TRULY / NATIVELY support 1024x768, but you can get it to pan and  scale to that resolution (which is 'effectively' the same thing).
Try running:
xrandr --output LVDS1 --panning 1024x768 --scale 1x1.28and to get back to normal
xrandr --output LVDS1 --panning 1024x600 --scale 1x1
If that works, you could create an autostart file that will run that command at boot.
If it doesn't work, post the output from:
xrandr
Personally I've added 2 menu items that switch between those resolutions
« Last Edit: December 06, 2014, 09:17:37 am by PCNetSpec »
