Author Topic: Google cloud print  (Read 2734 times)
Offline trelleboy
  • Peppermint version(s): 4
Google cloud print
« on: April 06, 2014, 02:37:01 pm »
I cant find anything om google cloud print in the forum. Maybe im blind - but can't find the subject.
I would like to print with google cloud print and save prints on my google drive. Is that possible?
Peppermint is great and perfect for schools - with a little more development..
Hope for some help with cloud printing
Offline mac
Re: Google cloud print
« Reply #1 on: April 06, 2014, 03:43:51 pm »
Hi trelleboy and welcome to the forum.
Open a terminal and run ...
sudo apt-get install cloudprint
After installing enter cloudprint
cloudprint
You will be prompted for your Google account info / password
after which it will add your printers.
Then, go to THIS SITE to manage your printers.
Reg. Linux User #432835
Offline kendall
  • Co-Founder
« Reply #2 on: April 07, 2014, 10:05:40 am »
Cloud Print is included by default in Google Chrome if you want to install it. I typically go that route in order to print to my Canon photo printer which doesn't have any Linux drivers. The printer is connected to a Windows 7 machine.
« Reply #3 on: April 07, 2014, 06:24:25 pm »
It's also in Chromium :)
