Author Topic: [SOLVED] Sharing files between pc's via home internet network [SOLVED]  (Read 1494 times)
Offline robertsala
Hi guys,
What's the best way to approach sharing files between pc's via wireless home network?
« Last Edit: December 21, 2014, 12:05:31 pm by robertsala »
Re: Sharing files between pc's via home internet neteork
« Reply #1 on: November 27, 2014, 12:37:50 pm »
Hi robertsala
There are various ways to do it gigolo makes it very easy to connect samba shares so that might be worth a try
Good luck
Offline robertsala
[SOLVED] Re: Sharing files between pc's via home internet neteork [SOLVED]
« Reply #2 on: November 27, 2014, 12:52:07 pm »
I'll give it a try...
« Last Edit: December 21, 2014, 12:03:57 pm by robertsala »
« Reply #3 on: November 27, 2014, 02:16:38 pm »
Install system-config-samba:
sudo apt-get install system-config-sambathen use
menu > System Tools > Samba
to configure the directories you want to share.
I think the first question should be .. What OS''s/Distro's are involved here besides Peppermint ?
