Author Topic: Docker security issue  (Read 1698 times)
Offline acer
« on: November 25, 2014, 05:28:53 am »
Is Docker within peppermint OS 5? as it seems to be in ubuntu 14.04
If it is, there seems to be 2  security issues that needs addressed..
http://www.theregister.co.uk/2014/11/25/docker_vulnerabilities/
Should we update manually or wait for ubuntu?
http://www.openwall.com/lists/oss-security/2014/11/24/5
Re: Docker security issue
« Reply #1 on: November 25, 2014, 06:23:27 am »
You're thinking of the "docker.io" package (the containerisation software) .. it's NOT installed in Peppermint by default (though it is available in the repos), and AFAIK it's not installed in Ubuntu by default either.
The package "docker" is just:-
Quote from: Synaptic Package Manager
Docker is a docking application (WindowMaker dock app) which acts as a system
tray for any desktop environment, allowing you to have a system tray without
running the KDE/GNOME panel Docker was designed to work with Openbox 2, but it
should work fine in any window manager.
But again "docker" is NOT installed in Peppermint by default either (but is available in the repos).
« Last Edit: November 25, 2014, 07:07:25 am by PCNetSpec »
Offline acer
« Reply #2 on: November 25, 2014, 06:34:00 am »
Thanks for the confirmation PCNetSpec  8)
