Author Topic: can someone recommend some good games for linux?  (Read 4201 times)
Offline iamesperambient
  • a totally awesome dude
« on: November 14, 2014, 08:32:36 pm »
I have an emulator and a usb nintendo controller and a bunch of nes roms but im looking for a newer game somethign exciting and entertaining
can anyone recommend something?
http://iamesper.bandcamp.com
boring drone music from NJ
Re: can someone recommend some good games for linux?
« Reply #1 on: November 14, 2014, 10:16:32 pm »
Hi iamesperambient
Steam are now porting more and more games over to Linux some are free to play
http://store.steampowered.com/
Good luck
« Reply #2 on: November 14, 2014, 10:20:25 pm »
thanks is this all browser based games or stuff i would have to download to my desktop?
« Reply #3 on: November 14, 2014, 10:25:08 pm »
im installing the client ill give it a go seems like they have a few good fun free games it seems to be all online based games which is cool saves  HD space :D
« Reply #4 on: November 14, 2014, 11:00:36 pm »
Steam is awesome and also a BIG friend to the Linux community.  You also get to use your Steam games on any machine you own. It keeps everything synced for you.  Half-Life on Steam is cracking good.  Its an oldie but a goodie.  I highly recommend it.  It runs great on older and lower spec machines.  You won't need an all singing and dancing video card.  I've only got an, Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller (rev 07) and Half-Life rock with it.  It cost me €10 so it will be about the same in dollars.  It really is well worth it - totally addictive  ;)
Here's a good command to find out what video card you have:
lspci -k | grep -A 2 -i "VGA"This is always good to know when you are looking at purchasing games - have fun  ;)!!
« Reply #5 on: November 14, 2014, 11:41:01 pm »
thanks for the info
is my graphics card bad?
« Reply #6 on: November 15, 2014, 10:21:00 am »
Erm yes...
That's a very weak graphics adapter for gaming .. so don't be expecting much from it.
« Reply #7 on: November 15, 2014, 12:56:09 pm »
 >:( that sucks well i will getting a new dell desktop
http://www.dell.com/us/p/inspiron-3647-small-desktop/pd?ref=PD_Family
its the only thing i can afford. i think peppermint should run on this thing unsure
if 32 or 64 bit but should work. if you can tell me if this is an 'ok ' graphics card
i would appreciate it that me help me decide to continue keeping it on the top
of the list to buy or bottom of the list.
« Reply #8 on: November 15, 2014, 02:23:31 pm »
Still not a gamer .. this may enlighten (same Celeron J1800 and baytrail HD graphics):
http://www.3dmark.com/fs/1874050
Another problem I have with that is I have no idea if it's expandable .. eg. can you add a better graphics card later. Doesn't mention anything about a PCIe slot anywhere that I can see.
What's your budget ?
« Reply #9 on: November 15, 2014, 09:58:29 pm »
aroun d 350 max is my budget so im looking for anything i can game on, make music on, do school work on and do the usual hulu/netflix watching
and do the usual surfing and of course run peppermint 5 any suggestions?
