Author Topic: how can i make a short cut to files? SOLVED  (Read 1094 times)
Offline iamesperambient
  • a totally awesome dude
« on: November 12, 2014, 09:47:47 pm »
so i dont like pacmanfm look wise so i started using Files which i think looks more clean and works well.
Obviously i can not delete pacman fm because it controls my desktop but i would like also like to make a shortcut for files
i tried in peppermint control center to make a short cut control > N but it didn't work am i putting the program name incorrectly?
i tried searching for this on the forum but i could not find a tutorial on setting this up.  I have it as a launcher on my dock but i usually
use shortcuts rather than the dock for a lot of things. thanks for any help.
« Last Edit: November 12, 2014, 10:20:07 pm by iamesperambient »
http://iamesper.bandcamp.com
boring drone music from NJ
Re: how can i make a short cut to files? SOLVED
« Reply #1 on: November 12, 2014, 10:20:57 pm »
ok so i didnt realize the command for it is still nautilus i thought it was changed to gnome files...got it working. so i was putting 'files' rather than nautilus
