Author Topic: No wifi on Lenovo 3000-v100 (SOLVED)  (Read 3408 times)
Offline Freiter
« on: November 12, 2014, 01:39:25 am »
Hi
I'm installing a new OS on my friends laptop. It's an Lenovo 3000-v100. I decided to try Peppermint because it's so light-weight.
Everything seems to be working except one thing - no wifi.. at all! it's completely dead. Dosn't work with an ethernet either.
I'm not very experienced in Linux, but I would really like it to work, so I don't have to install Windows XP on it again.
I looked at another thread about wifi problems and followed the instructions there:
jannie@jannie-LENOVO3000-V100 ~ $ sudo lshw -C network
  *-network DISABLED
       product: PRO/Wireless 3945ABG [Golan] Network Connection
       vendor: Intel Corporation
       physical id: 0
       bus info: pci@0000:04:00.0
       logical name: wlan0
       version: 02
       serial: 00:1b:77:05:ce:07
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwl3945 driverversion=3.13.0-29-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11abg
       resources: irq:43 memory:d6000000-d6000fff
  *-network
       product: RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
       physical id: 7
       bus info: pci@0000:0a:07.0
       logical name: eth0
       version: 10
       serial: 00:16:d3:b1:f6:2f
       capacity: 100Mbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=half latency=32 link=no maxlatency=64 mingnt=32 multicast=yes port=MII speed=10Mbit/s
       resources: irq:20 ioport:4000(size=256) memory:d8001800-d80018ff
jannie@jannie-LENOVO3000-V100 ~ $ lspci -vnn | grep -i net
04:00.0 Network controller [0280]: Intel Corporation PRO/Wireless 3945ABG [Golan] Network Connection [8086:4227] (rev 02)
0a:07.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter [10ec:8139] (rev 10)
jannie@jannie-LENOVO3000-V100 ~ $ lsusb
Bus 001 Device 002: ID 0402:5602 ALi Corp. M5602 Video Camera Controller
Bus 004 Device 002: ID 08ff:1600 AuthenTec, Inc. AES1600
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
jannie@jannie-LENOVO3000-V100 ~ $ iwconfig
wlan0     IEEE 802.11abg  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=off
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
eth0      no wireless extensions.
jannie@jannie-LENOVO3000-V100 ~ $ ifconfig
eth0      Link encap:Ethernet  HWaddr 00:16:d3:b1:f6:2f
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          RX packets:752 errors:0 dropped:0 overruns:0 frame:0
          TX packets:752 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:59600 (59.6 KB)  TX bytes:59600 (59.6 KB)
jannie@jannie-LENOVO3000-V100 ~ $ iwlist scanning
wlan0     Failed to read scan data : Network is down
eth0      Interface doesn't support scanning.
jannie@jannie-LENOVO3000-V100 ~ $ rfkill list
0: acer-wireless: Wireless LAN
   Soft blocked: yes
   Hard blocked: no
1: phy0: Wireless LAN
   Soft blocked: no
   Hard blocked: yes
I Would really appreciate it, if anyone could help.
« Last Edit: November 13, 2014, 09:50:15 am by Freiter »
Re: No wifi on Lenovo 3000-v100
« Reply #1 on: November 12, 2014, 06:00:44 am »
Is there a physical hardware switch on the PC somewhere .. or a key combo (such as Fn+F8 or similar) ?
If not, what happens if you run:
sudo rfkill unblock alldoes wireless spring to life ?
If not, can you post the output from:
lsmod | grep wmi
Offline Freiter
« Reply #2 on: November 12, 2014, 07:31:15 am »
thx for quick reply.
Fn+F5 seems to have something to do with wifi, but it does not respond. The Fn does work, but not this one.
Here is  output:
jannie@jannie-LENOVO3000-V100 ~ $ sudo rfkill unblock all
jannie@jannie-LENOVO3000-V100 ~ $ lsmod | grep wmi
acer_wmi               31735  0
sparse_keymap          13708  1 acer_wmi
snd_rawmidi            25135  1 snd_seq_midi
snd_seq_device         14137  3 snd_seq,snd_rawmidi,snd_seq_midi
snd                    60871  17 snd_hda_codec_realtek,snd_hda_codec_si3054,snd_hwdep,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec,snd_hda_intel,snd_seq_device,snd_seq_midi
wmi                    18673  1 acer_wmi
video                  18903  2 i915,acer_wmi
Offline Freiter
« Reply #3 on: November 12, 2014, 07:36:32 am »
I've read somewhere, that Lenovo used to put some really bad cards in some of there laptops, that wouldn't last very long. Could it be, that it simply dosn't work anymore?
« Reply #4 on: November 12, 2014, 09:15:03 am »
Possibly,  .. but I'm more of the opinion it has something to do with acer-wmi ..  is there any option in the BIOS to enable wireless switching (or similar) ?
What happens if you run:
sudo modprobe -r sparse_keymap acer-wmi wmi iwl3945then
sudo rfkill unblock all?
« Last Edit: November 12, 2014, 09:36:15 am by PCNetSpec »
rjm65
  • Guest
« Reply #5 on: November 12, 2014, 09:26:23 am »
depending on what model lenovo this is, my lenovos all have a hard switch on the front of them, that can sometimes be mistaken for the cover release and flipped off when trying to open the laptop up....   ;)
rjm65
  • Guest
« Reply #6 on: November 12, 2014, 09:33:26 am »
I did a little digging on google and found this picture hope it helps you there is a switch on the machine for the wifi on the side by the cd/dvd rom drive....
« Reply #7 on: November 12, 2014, 09:39:29 am »
Nice find rjm65 :)
Offline Freiter
« Reply #8 on: November 12, 2014, 09:54:30 am »
Okay, so I switched the wifi on and it says in the BIOS that wifi is enabled, but nothings changed.
This is the output from the terminal:
jannie@jannie-LENOVO3000-V100 ~ $ sudo modprobe -r sparse_keymap acer-wmi wmi iwl3945
modprobe: FATAL: Module sparse_keymap is in use.
Offline Freiter
« Reply #9 on: November 13, 2014, 08:48:17 am »
Does it look hopeless? Should I just tell her to buy a new laptop?
« Reply #10 on: November 13, 2014, 09:24:13 am »
NO .. a USB wireless adapter is MUCH cheaper than a new laptop ;)
That said we're not finished here yet...
What's the output from:
rfkill listnow ?
If it's still hardblocked, and the Fn+F5 key combo still refuses to enable it .. try below...
Run:
sudo gedit /etc/modprobe.d/blacklist.confwhen gedit opens, add a single NEW LINE at the bottom that reads:-
blacklist acer-wmi
SAVE the file and exit gedit
Now REBOOT
Now what;s the output from:
rfkill list?
« Last Edit: November 13, 2014, 09:26:54 am by PCNetSpec »
Offline Freiter
« Reply #11 on: November 13, 2014, 09:49:54 am »
Now all of a sudden the wifi works!  :) it said something about scanning for brstf something when I started it up right now, and then it just worked..
thank you very much for your help!
Re: No wifi on Lenovo 3000-v100 (SOLVED)
« Reply #12 on: November 13, 2014, 10:30:50 am »
Without you doing anything ? .. or after blacklisting acer-wmi ?
Offline Freiter
« Reply #13 on: November 13, 2014, 11:31:24 am »
it must be some of the things I did yesterday..
anyway, thx very much!
