Author Topic: How do I Auto Start Guake or other new terminal emulator? SOLVED  (Read 2176 times)
Offline iamesperambient
  • a totally awesome dude
« on: November 06, 2014, 02:44:54 pm »
trying to install and autostart Guake with out having to load it first from the menu is this possible?
if this isn't how to i change my default terminal to possible xfce4 terminal ( it has less glitchy on my system
than lxterminal) but prefer Guake.
« Last Edit: November 06, 2014, 03:02:46 pm by iamesperambient »
http://iamesper.bandcamp.com
boring drone music from NJ
Re: How do I Auto Start Guake or other new terminal emulator?
« Reply #1 on: November 06, 2014, 02:56:21 pm »
Open a terminal window and enter the following command:
gedit ~/.config/autostart/guake-autostart.desktopWhen the empty file opens, copy and paste the following contents into it:
[Desktop Entry]
Name=Guake Autostart
Comment=autostart guake terminal emulator
Exec=guake
Terminal=true
Save the file.  Logout and login to test  - have fun  ;)!!
« Reply #2 on: November 06, 2014, 02:57:35 pm »
thanks ill let you know if it works :D
« Reply #3 on: November 06, 2014, 02:59:30 pm »
Or just run:
cp -v /usr/share/applications/guake.desktop ~/.config/autostart/guake.desktopthen log off/on to test it autostarts
« Reply #4 on: November 06, 2014, 03:02:36 pm »
thanks it worked ! sorry i didn't be before your shorter command but it worked :D
now if i could only solved the problem in my other thread :D thanks again guys!
my linux for dummies book should arrive soon so i can stop bothering you all haha
« Reply #5 on: November 06, 2014, 03:59:47 pm »
No problem, please remember to mark the topic as [SOLVED]. Thanks  ;)
