Author Topic: Slow Loading (SOLVED)  (Read 9431 times)
Online rjm65
Re: Slow Loading
« Reply #15 on: January 01, 2015, 03:35:49 pm »
andy if her emails and web pages are slow loading I don't think deleting kernels is going to help her out...  She has the same machine I do and my wifi works great, but PCNetSpec hooked me up with the proper driver for mine because p5 did not have the driver for it built in...
If you look at the inxi F on my machine card is identical....
http://forum.peppermintos.com/index.php/topic,1325.0.html
I would be willing to bet she has to install the same driver I did to get it to function properly...
these are the instructions PCNetSpec gave to me to get mine working right...
For Peppermint 5, connect to your router via an ethernet cable and run:
sudo apt install b43-fwcutter firmware-b43-installer firmware-b43legacy-installer linux-firmware-nonfree
wireless should work now.
Robert
Peppermint 9 User
Gateway Solo 9300 Pro
IBM T40
Offline evie7
  • Peppermint version(s): 5
Re: Slow Loading
« Reply #16 on: January 01, 2015, 03:50:54 pm »
output #1:
output#2:
output#3:
Re: Slow Loading
« Reply #17 on: January 01, 2015, 03:54:16 pm »
Well we can try the wl wireless driver instead of b43, but I'm not sure this is going to help if EVERYTHING is slow .. or is it just the internet that's slow ?
(bearing in mind an Intel Atom N270 is never going to breath fire)
As you seem to have an SSD, what's the output (if any) from:
sudo hdparm -I /dev/sda | grep TRIM
« Last Edit: January 01, 2015, 04:04:48 pm by PCNetSpec »
Offline evie7
Re: Slow Loading
« Reply #18 on: January 01, 2015, 04:07:52 pm »
I entered sudo hdparm -I /dev/sda | grep TRIM in terminal and got nothing...
Seems like everything is slow, not just the internet... opening the software manager took a minute...
Offline evie7
Re: Slow Loading
« Reply #19 on: January 01, 2015, 04:12:56 pm »
Also, I did this a while back because I couldn't get a wifi connection:
and someone said to do it. Maybe it was you, Robert?
So that was already done?
Sorry if I'm confusing the matter...
Re: Slow Loading
« Reply #20 on: January 01, 2015, 04:19:50 pm »
The software manager has always been a slow program to load (though a minute is certainly excessive)  .. how about other apps ? .. and have they got slower over time or have they always been slow ?
SSD's that don't support TRIM will likely get slower (for write operations) over time, but there's nothing that can be done about it besides a secure erase/format/reinstall ... see:
https://en.wikipedia.org/wiki/Trim_%28computing%29
https://wiki.archlinux.org/index.php/SSD_memory_cell_clearing
but BE AWARE a secure erase will COMPLETELY wipe the drive .. so don't do itt unless you plan on reinstalling from scratch.
« Last Edit: January 01, 2015, 04:48:38 pm by PCNetSpec »
Online rjm65
Re: Slow Loading
« Reply #21 on: January 01, 2015, 04:35:00 pm »
No it wasn't me I only mentioned it today when I seen our machines were quite the same however i do not have an ssd drive I have a plain sata 160 gb drive...
I also complained about slowness on mine on bootup, but i got that down to about 50 seconds which i can live with, but you are right the machine does seem slow all around, compared to my asus eee which has the same processor and hard drive, the asus flies and the dell is just blah-zay at best....  Maybe its a dell issue with the linux kernel who knows...  but i know what you are saying about slowness, cause i am experiencing it also...
Robert
Peppermint 9 User
IBM T40
Offline evie7
Re: Slow Loading
« Reply #22 on: January 01, 2015, 04:51:03 pm »
Yeah, now that I checked, other programs are loading about the same as they did. I guess it's just the internet? You said something about trying another driver instead?  Also, I am a technology savant  :-[ when you talk about an ssd not supporting trim yada yada, my eyes kinda glaze over. I did, however, all on my own somehow, replace the drive awhile back. I can't tell you how I did it, though. I can't explain why I love this little dell so. It's really weird, I know...Just tell me the truth, is it time to let her go?... :'(
Re: Slow Loading
« Reply #23 on: January 01, 2015, 04:55:40 pm »
Not necessarily .. I have a bunch of netbooks, all of which also have Intel Atom N270 processors (same as yours), and I wouldn't be without them (in fact I'm answering you now on an Acer Aspire One) .. but just don't expect too much from them speed wise ;)
Anyway, we can try the wl drivers if you'd like ? .. but before we do, can you check if the internet is any quicker with a cabled connection ? .. if it isn't, then changing the wireless driver is not going to make a difference.
It will also be a good idea to  see if just clearing your browser cache makes a difference .. which web browser are you using ? and I'll post instructions.
So this SSD is fairly new ?
Just to get an idea of the condition of your SSD, can you install smartmontools with this command:
sudo apt-get install smartmontoolsthen post the output from:
sudo smartctl -a /dev/sda
[EDIT 2]
It'd also be a good idea to run a file system check .. open a terminal and run:
sudo touch /forcefsckthen REBOOT .. a file system check will automagically run during the reboot.
« Last Edit: January 01, 2015, 05:30:20 pm by PCNetSpec »
Re: Slow Loading
« Reply #24 on: January 01, 2015, 04:56:23 pm »
Hi Robert, Happy New Year mate  ;).  Yeh, I didn't think clearing the garbage out would do much.  I just saw from an earlier post that it maybe needed doing, so I though I'd help Evie do it anyway.  I'm really curious to see the outcome of this one though.
Sorry Evie, I wasn't talking over your head, I'm just really interested to see your machine get up to speed - good luck  ;)!
Online rjm65
Re: Slow Loading
« Reply #25 on: January 01, 2015, 05:06:21 pm »
Happy New Year to you to Andy, Yeah I am watching this one too... Hoping to gain a little insight on speeding it up a bit if it is possible, I know my asus is the same all around as my dell, except it has the 2 gig ram and the dell only has 1 gig...  I was going to upgrade the dell mini to 2 gig until i watched the video on how to do so, and i just laughed and said I'll live with 1 gig for now...  you have to remove the entire motherboard, and flip it over to replace the ram chip...  Dumb design, they could have easily put a cut out in the bottom of the machine, with a cover plate and screw, but they decided to make it impossible for joe average to upgrade his ram....
Robert
Peppermint 9 User
IBM T40
Offline evie7
Re: Slow Loading
« Reply #26 on: January 01, 2015, 07:06:03 pm »
Ok you guys,
I'll let you know if the wired connection is better. I might have to do it tomorrow, though.  In the meantime here's what I got from smartmontools:
I also did the file system check and rebooted.
I think I know how to clear the the cache. Should I do that now?... it's chromium
Offline evie7
Re: Slow Loading
« Reply #27 on: January 02, 2015, 01:30:06 pm »
Hi You Guys,
Yeah, it's not the connection because a wired connection was still sloooooow.  So is my only option to start from scratch?
Could it be a problem with Chromium? It seems to me, in the cob-webbed corners of my mind,  that I read somewhere that one should only run Chromium with Peppermint, not Chrome, and trying to run it would mess it up even if you switched back. I think that happened to me because when I first installed Peppermint 5, I signed in to Google and it thought I meant Chrome but then I signed out because I remembered someone saying to only use Chromium.  If this is all duh and doesn't make sense, please remember that I can only act like I know even the slightest bit of this stuff and I do everything by feel... :-[
Re: Slow Loading
« Reply #28 on: January 02, 2015, 01:41:10 pm »
No that's simply not true .. Peppermint 5 is happy with either Chrome or Chromium (or indeed both, or any other browser).
Can't hurt to try Firefox though .. install it with:
sudo apt-get install firefox flashplugin-installerthen see if Firefox is also slow.
If it ISN'T slow, we can try clearing the Chromium cache .. or you can stick with firefox
Or we can try clearing the Chromium cache first if you'd like ?
« Last Edit: January 02, 2015, 01:43:28 pm by PCNetSpec »
Offline evie7
Re: Slow Loading
« Reply #29 on: January 02, 2015, 01:57:57 pm »
Just looking through posts about browsers, I see that there's this "qupzilla" ? I'm not attached to any particular browser. Should I try that one? If not , how do I clear the cache?
