Author Topic: Dell AD1885 Integrated Audio Sounds Bad  (Read 2694 times)
Offline dazed63
« on: April 02, 2014, 03:03:52 pm »
I'm not sure if this is just the pc being old or something is missing. Dell Opitplex 150, with AD1885 Integrated Audio. The sound quality is horrible, I even swapped out computer speakers from another pc where the sound is good.  I'm using Exaile and it's mixer.
I had the pc laying in a box and figured it would make a good "jukebox" for my workout area and dump the "boombox" and CD's. But the sound quality is driving me nuts.
Any help would be greatly appreciated.
Peppermint: 4-20130611-i386.iso
Re: Dell AD1885 Integrated Audio Sounds Bad
« Reply #1 on: April 02, 2014, 03:32:24 pm »
Have you checked if pulseaudio makes a difference ?
Open a terminal and run:
sudo apt-get install pulseaudio pulseaudio-utils pavucontrol
then if necessary, log off/on (or reboot)
did that help ?
You should also now have a new menu item at
menu > Sound & Video > PulseAudio Volume Control
you might want to look around in there.
Offline dazed63
« Reply #2 on: April 03, 2014, 12:28:41 pm »
I have not.
I will try that tonight.
Thank you for the reply.
dazed63
Offline d1g1tal
  • Peppermint version(s): 4
« Reply #3 on: April 14, 2014, 06:05:51 pm »
You could try these suggestions, not used them myself, just stumbled across them.
https://wiki.archlinux.org/index.php/Advanced_Linux_Sound_Architecture#Poor_sound_quality_or_clipping
