Author Topic: Screenshot Gallery -- Show Us Your Screen  (Read 68176 times)
Offline zarg2
  • let the people you love know it
Re: Screenshot Gallery -- Show Us Your Screen
« Reply #390 on: December 08, 2019, 06:53:23 pm »
zarg2, that's a nice look. :)
...I need to pay for my trash on eBay (or Goodwill)  :))
-- VinDSL
 Me too! :))
I,ve had luck with trashed computers over the years. Pcliquidations.com is pretty good too. But nothing beats free.
Dell Dimension 4700 - Peppermint 10 32 bit on Kingston A400 SSD
ACER Desktop Athlon 64X2 - Peppermint 10
Acer C720P 32GB SSD 4GB Memory Ex- Chromebook GaliumOS
"You have today; use it well & be kind"
Offline rayzer
  • Graphics n Stuff
« Reply #391 on: January 08, 2020, 06:05:44 am »
my 'pepuntu' install, some parts are peppermint and the system recognises it as ubuntu 18.04.3 due to some haywire updates
Offline darknet
  • /home/darknet
  • Peppermint version(s): Peppermint 10 respin 64-bit
« Reply #392 on: January 09, 2020, 06:04:12 am »
my new install, viking-inspired
Online RedWhite Canuck
  • Peppermint version(s): 9R, 10R
« Reply #393 on: February 05, 2020, 03:25:24 pm »
Hi all, here is my screen and a question:  How do I shrink the task bar icons in the notification area to take up less vertical space?
https://www.dropbox.com/s/6fj2k6jmftjymzc/Selection_008.png?dl=0
I am not doing much theming. I have arranged the task bar to vertical to give better working real estate.  The task bar feature "Window Menu" allows me to switch tasks easily without taking up much space.  However, the notification area icons are too large.
I also move the window title bar buttons to the left to minimize mouse distance.
Any ideas on where/how I can modify these icons would be appreciated.
« Last Edit: February 05, 2020, 03:43:26 pm by RedWhite Canuck »
Offline Fritz74
  • m, 46, Austria
« Reply #394 on: February 09, 2020, 07:32:16 am »
Maybe hiding certain icons in the notification area is an option. You can make them visible if you need them.
To do this, go to panel settings, then objects and edit the notification area. Select hidden for the icons you don't want to see all the time.  Instead of those icons there will be a little arrow that makes them visible if you click it.
« Reply #395 on: February 09, 2020, 09:46:37 am »
Thanks Fritz!  Editing the Notification area under panel preferences fixed it.
At first, I changed the Max Icon Size from 44 to 34 and nothing happened.  However, clicking to 26 made a big jump and they are now correctly sized.
Offline ciampak
« Reply #396 on: March 04, 2020, 10:42:26 am »
My Peppermint 10 respin
Offline stevesveryown
  • Peppermint Fan
    • stevesveryown
« Reply #397 on: March 05, 2020, 05:48:41 am »
Clampak, You may be trying to post an image right to the forum which you can't.  Check out the following link from the forum on how to use Imgur.
https://forum.peppermintos.com/index.php/topic,4284.0.html
Offline rayzer
  • Graphics n Stuff
« Reply #398 on: March 05, 2020, 12:32:58 pm »
i opened your link above, right clicked image and copied image location. then just wrapped with img tags
Offline rayzer
  • Graphics n Stuff
« Reply #399 on: March 05, 2020, 01:29:30 pm »
heres a quick one of mine
Offline Fritz74
  • m, 46, Austria
« Reply #400 on: March 05, 2020, 02:05:24 pm »
clampak's desktop looks great! Maybe he'll be enlightened just by using Peppermint. :)
I like the simple elegance of rayzer's desktop too. That Gotham theme for Conky is getting old, though. Everyone, including myself, is using it. ;)
« Last Edit: March 06, 2020, 10:32:37 am by Fritz74 »
Offline coyote
  • Peppermint Lover
  • Peppermint version(s): Peppermint 10 Respin (64bit)
« Reply #401 on: March 15, 2020, 07:59:16 am »
my p10r...
« Last Edit: March 15, 2020, 08:04:04 am by coyote »
« Reply #402 on: March 15, 2020, 08:16:31 am »
Offline Fritz74
  • m, 46, Austria
« Reply #403 on: May 26, 2020, 09:28:57 am »
My current desktop:
Different panels with different background colors.
Offline The Omen
« Reply #404 on: May 26, 2020, 10:15:19 am »
How do you add a screenshot here ?
I cannot figure it out.
Thanx,
The Omen
