Author Topic: No Wi-Fi? (Solved)  (Read 13157 times)
Offline _tuter
  • 18 yrs old - Distro Hopper - Peppermint Lover
  • Peppermint version(s): Peppermint OS 6!!
Re: No Wi-Fi?
« Reply #15 on: April 02, 2014, 06:19:04 pm »
Sorry, been meaning to answer, no it didnt work even with the live usb. Idk what my other options are.
:) _tuter :)
Offline _tuter
Re: No Wi-Fi?
« Reply #16 on: April 02, 2014, 06:42:10 pm »
No, it didn't work in the live usb.  :'(
:) _tuter :)
Re: No Wi-Fi?
« Reply #17 on: April 03, 2014, 02:30:52 am »
Would this neighbour be amenable to temporarily letting you connect by cable or temporarily switching off wireless security, or possibly switching to AES encryption rather than TKIP ?
Offline _tuter
Re: No Wi-Fi?
« Reply #18 on: April 03, 2014, 05:39:58 pm »
Honestly, I don't know if they would, but it doesn't hurt to ask i guess. If i was connected to the wired ethernet connection and had my wlan adapter connected, would I then be able to download the appropriate drivers for my wifi adapter? Where would i go to start to download the drivers? Thanks in advance.  :)
:) _tuter :)
Re: No Wi-Fi?
« Reply #19 on: April 04, 2014, 05:17:10 am »
If you can somehow get the PC connected to the interweb, then whilst connected, open a terminal and run these commands in sequence:
sudo apt-get updatethen
sudo apt-get upgradethen
sudo apt-get dist-upgradethen REBOOT (this is important)
then after the reboot re-open the terminal and run:
sudo apt-get install linux-headers-generic build-essential dkms linux-firmware-nonfree linux-firmwareThen we can probably do the rest offline by downloading the necessary drivers on the PC you're using now.
In a short while, I'll post what you need to do next to download and install the drivers .. but in the meantime if you get te chance to do the above .. DO IT.
Can you answer a few questions.....
Is the PC you're using now connected wirelessly ?
Which OS is it running ?
Would it be possible to get the 2 PC's in close proximity (length of an ethernet cable) ?
Have you got an ethernet cable ?
The reason I ask is we may be able to share it's internet connection with the Peppermint PC whilst we fix things
Offline _tuter
Re: No Wi-Fi?
« Reply #20 on: April 04, 2014, 10:17:33 am »
I've been mainly using my tablet to post on this forum, I do have a laptop that is connected to the same wireless network, the laptop that is connected to my wireless network is running os windows 7,yes i can get them in close proximity, with in a few feet, I don't know if i have an ethernet cable, I may , but may not. I will have to check and get back to you!! Thanks!!  :D ;D :D
:) _tuter :)
Offline _tuter
Re: No Wi-Fi?
« Reply #21 on: May 22, 2014, 08:32:07 pm »
Hey,
just wondering what the next step would be as I now have a wired connection?
Please respond!!
:) _tuter :)
Re: No Wi-Fi?
« Reply #22 on: May 23, 2014, 09:52:49 am »
mkdir ~/Desktop/8192cu-tempthen
cd ~/Desktop/8192cu-tempthen
wget https://dl.dropboxusercontent.com/u/11876059/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911.tar.gzthen
tar xvf rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911.tar.gzthen
cd ~/Desktop/8192cu-temp/rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911then
makethen
sudo make installthen
sudo modprobe -r rtl8192cuthen
sudo modprobe 8192cuDoes wireless spring to life .. if so, check it survives a reboot.
Offline _tuter
Re: No Wi-Fi?
« Reply #23 on: May 23, 2014, 11:35:49 am »
Seems to work even after a reboot, but does take a couple of tries to connect, but at least it works!! :D
Thanks!!
:) _tuter :)
Re: No Wi-Fi? (Solved)
« Reply #24 on: May 23, 2014, 02:58:04 pm »
You're welcome .. thanks for marking the topic solved :)
