Author Topic: [SOLVED] Keyboard not recognised  (Read 6017 times)
Offline DimitrisRHO
  • Peppermint version(s): 5
« on: September 27, 2014, 12:33:26 pm »
Hello all, after having peppermint3 and 4 I decided to install 5, strangely while installation the keyboard is not recognised so I can not go further installing it. It is a LG R500 laptop.
Strangely I also lost my account in the forum here so I had to register again.
« Last Edit: October 03, 2014, 05:40:27 am by DimitrisRHO »
Offline DimitrisRHO
Re: Keyboard not recognised
« Reply #1 on: September 27, 2014, 10:39:46 pm »
I have found this but I dont really understand how to make these steps, could someone explain me?
https://bugs.launchpad.net/ubuntu/+source/initramfs-tools/+bug/1238194
« Reply #2 on: September 28, 2014, 04:51:05 am »
Have you got an external keyboard you can use for the installation ?
Then we can look into adding the initramsf modules to the installed OS
Offline DimitrisRHO
« Reply #3 on: September 28, 2014, 10:52:02 am »
I could find an external one, would it be recognize for sure? and how do I install initransfm?
I just noticed that the old forum has moved    :D
« Reply #4 on: September 28, 2014, 11:42:37 am »
Heh!   :D
Old Forum -- New Link:  http://forum.peppermintos.com/index.php/board,23.0.html
And, old doesn't mean forgotten.  There's still a LOT of useful info over there.
Currently, the Old Forum, as we 'speak'......
In total there are 12 users online :: 3 registered, 0 hidden and 9 guests (based on users active over the past 5 minutes)
Most users ever online was 196 on Wed Mar 05, 2014 5:38 am
Currently, this New Forum...
16 Guests, 1 User (2 Spiders)
Most Online Ever: 77 (August 20, 2014, 10:07:55 AM)
Okay, back on topic.   8)
« Last Edit: September 28, 2014, 11:56:49 am by VinDSL »
« Reply #5 on: September 28, 2014, 12:24:54 pm »
Haven't a clue until you try one ;)
and initramfs is the initial image that gets loaded into RAM to initialise/load the rest of the OS .. initramfs-tools should already be installed .. you just need to edit a file, then generate a new initramfs file .. We'll get round to trying that if/when you confirm you're able to run the LiveCD/LiveUSB with an external USB keyboard.
Offline DimitrisRHO
« Reply #6 on: September 29, 2014, 02:02:34 am »
ok, thanks, I will let you know as soon as I get an external keyboard, thanks.   8)
Offline DimitrisRHO
« Reply #7 on: October 01, 2014, 10:53:35 am »
ok, I got it installed with an external USB keyboard that works fine. So what can I do now to make my laptops keyboard working?
« Reply #8 on: October 02, 2014, 06:13:52 am »
OK, if you've already installed Peppermint 5 .. boot using your external keyboard, open a terminal and run:
sudo gedit /etc/initramfs-tools/moduleswhen a file with some stuff already in it opens, add these 4 NEW lines at the bottom
hid
usbhid
hid_generic
ohci_pci
SAVE the file, and close gedit.
Back in the terminal, run:
sudo update-initramfs -uwhen that command finishes and leaves you back at an $ prompt .. REBOOT and test your internal keyboard.
Offline DimitrisRHO
« Reply #9 on: October 02, 2014, 12:05:33 pm »
sadly nothing  :'(
Offline DimitrisRHO
« Reply #10 on: October 02, 2014, 12:09:03 pm »
how can I change the kernel?
« Reply #11 on: October 02, 2014, 01:04:06 pm »
To which kernel version ?
Have you tried running a full system update and seeing if that makes any difference ? .. with an active internet connection (wired or wireless) open a terminal and run these commands in sequence:
sudo apt-get updatethen
sudo apt-get upgradethen
sudo apt-get dist-upgradethen REBOOT
« Last Edit: October 02, 2014, 01:07:13 pm by PCNetSpec »
Offline DimitrisRHO
« Reply #12 on: October 02, 2014, 01:19:21 pm »
 :-\ nothing  :'(
Offline DimitrisRHO
« Reply #13 on: October 02, 2014, 01:36:46 pm »
I have read in other forums going to previous kernels it worked  :(
« Reply #14 on: October 02, 2014, 01:48:50 pm »
You'd have to givee me more than that .. WHICH kernel is supposed to work ?
