Author Topic: very slow internet on Peppermint (no longer solved?)  (Read 9887 times)
Re: very slow internet on Peppermint (no longer solved?)
« Reply #30 on: October 10, 2014, 04:07:44 pm »
I see no excessive transmit/receive errors between the wireless card and your router .. so I still think this is an encryption issue.
Can you TEMPORARILY disable wireless encryption in your router and see if that makes a difference.
You can re-enable it after testing.
Offline kskarda
« Reply #31 on: October 12, 2014, 08:52:03 pm »
At the moment, we are visiting friends, so we can't mess with their router. However, this has been the case on three different routers and only with my husband's computer (I am using my computer to send this message). Also, there was no internet challenge before Peppermint. I'm just wondering if I should try reinstalling Peppermint all over again. It would be a hassle, but maybe something went wrong during the installation.
« Reply #32 on: October 12, 2014, 10:12:13 pm »
I'm thinking it might be easier to just get one of these
http://www.edimax.com/edimax/merchandise/merchandise_detail/data/edimax/in/wireless_adapters_n150/ew-7811un/
which should work "out of the box" in Peppermint 5
Offline kskarda
« Reply #33 on: October 13, 2014, 11:38:15 pm »
Okay, my next round of trial and error to get internet working...  my my nephew gave me his old SMC toggle (SMCWUSBS-N3). I downloaded the driver and opened the Read Me file and can't understand it all. (I don't at the moment have access to the exact product you recommended).  I'm not actually sure if it works in Peppermint.
I am copying and pasting the Read Me file here:
README
* Ralink Tech Inc.
* http://www.ralinktech.com
ModelName:
RT2870 Wireless Lan Linux Driver
Driver lName:
rt2870.o/rt2870.ko
Supporting Kernel:
linux kernel 2.4 and 2.6 series.
Tested in Redhat 7.3 or later.
Ralink Hardware:
Ralink 802.11n Wireless LAN Card.
Description:
This is a linux device driver for Ralink RT2870 USB ABGN WLAN Card.
Contents:
Makefile           : Makefile
*.c               : c files
*.h               : header files
Features:
   This driver implements basic IEEE802.11. Infrastructure and adhoc mode with
   open or shared or WPA-PSK or WPA2-PSK authentication method.
   NONE, WEP, TKIP and AES encryption.
Build Instructions:
1> $tar -xvzf DPB_RT2870_Linux_STA_x.x.x.x.tgz
    go to "./DPB_RT2870_Linux_STA_x.x.x.x" directory.
2> In Makefile
    set the "MODE = STA" in Makefile and chose the TARGET to Linux by set "TARGET = LINUX"
    define the linux kernel source include file path LINUX_SRC
    modify to meet your need.
3> In os/linux/config.mk
   define the GCC and LD of the target machine
   define the compiler flags CFLAGS
   ** Build for being controlled by NetworkManager or wpa_supplicant wext functions
      Please set 'HAS_WPA_SUPPLICANT=y' and 'HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=y'.
      => #>cd wpa_supplicant-x.x
      => #>./wpa_supplicant -Dwext -ira0 -c wpa_supplicant.conf -d
   ** Build for being controlled by WpaSupplicant with Ralink Driver
      Please set 'HAS_WPA_SUPPLICANT=y' and 'HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=n'.
      => #>cd wpa_supplicant-0.5.7
      => #>./wpa_supplicant -Dralink -ira0 -c wpa_supplicant.conf -d
4> $make
   # compile driver source code
   # To fix "error: too few arguments to function ¡¥iwe_stream_add_event"
     => $patch -i os/linux/sta_ioctl.c.patch os/linux/sta_ioctl.c
5> $cp RT2870STA.dat  /etc/Wireless/RT2870STA/RT2870STA.dat
6> load driver, go to "os/linux/" directory.
    #[kernel 2.4]
    #    $/sbin/insmod rt2870sta.o
    #    $/sbin/ifconfig ra0 inet YOUR_IP up
    #[kernel 2.6]
    #    $/sbin/insmod rt2870sta.ko
7> unload driver
    $/sbin/ifconfig ra0 down
   $/sbin/rmmod rt2870sta
CONFIGURATION:
RT2870 driver can be configured via following interfaces,
i.e. (i)"iwconfig" command, (ii)"iwpriv" command, (iii) configuration file
i)  iwconfig comes with kernel.
ii) iwpriv usage, please refer to file "iwpriv_usage.txt" for details.
iii)modify configuration file "RT2870STA.dat" in /etc/Wireless/RT2870STA/RT2870STA.dat.
Configuration File : RT2870STA.dat
# Copy this file to /etc/Wireless/RT2870STA/RT2870STA.dat
# This file is a binary file and will be read on loading rt.o module.
# Use "vi RT2870STA.dat" to modify settings according to your need.
# 1.) set NetworkType to "Adhoc" for using Adhoc-mode, otherwise using Infrastructure
# 2.) set Channel to "0" for auto-select on Infrastructure mode
# 3.) set SSID for connecting to your Accss-point.
# 4.) AuthMode can be "WEPAUTO", "OPEN", "SHARED", "WPAPSK", "WPA2PSK", "WPANONE"
# 5.) EncrypType can be "NONE", "WEP", "TKIP", "AES"
# for more information refer to the Readme file.
#The word of "Default" must not be removed
Default
CountryRegion=5
CountryRegionABand=7
CountryCode=
SSID=Dennis2860AP
NetworkType=Infra
WirelessMode=9
Channel=0
BeaconPeriod=100
TxPower=100
BGProtection=0
TxPreamble=0
RTSThreshold=2347
FragThreshold=2346
TxBurst=1
WmmCapable=0
AckPolicy=0;0;0;0
AuthMode=OPEN
EncrypType=NONE
WPAPSK=
DefaultKeyID=1
Key1Type=0
Key1Str=
Key2Type=0
Key2Str=
Key3Type=0
Key3Str=
Key4Type=0
Key4Str=
PSMode=CAM
FastRoaming=0
RoamThreshold=70
HT_RDG=1
HT_EXTCHA=0
HT_OpMode=1
HT_MpduDensity=4
HT_BW=1
HT_AutoBA=1
HT_BADecline=0
HT_AMSDU=0
HT_BAWinSize=64
HT_GI=1
HT_MCS=33
HT_MIMOPSMode=3
EthConvertMode=
EthCloneMac=
IEEE80211H=0
TGnWifiTest=0
WirelessEvent=0
MeshId=MESH
MeshAutoLink=1
MeshAuthMode=OPEN
MeshEncrypType=NONE
MeshWPAKEY=
MeshDefaultkey=1
MeshWEPKEY=
CarrierDetect=0
*NOTE:
   WMM parameters
         WmmCapable         Set it as 1 to turn on WMM Qos support
         AckPolicy1~4      Ack policy which support normal Ack or no Ack
                        (AC_BK, AC_BE, AC_VI, AC_VO)
   All WMM parameters do not support iwpriv command but ¡¥WmmCapable¡Š¡Š,
   please store all parameter to RT2870STA.dat, and restart driver.
syntax is 'Param'='Value' and describes below.
@> CountryRegion=value
   value
      0: use 1 ~ 11 Channel
      1: use 1 ~ 13 Channel
      2: use 10 ~ 11 Channel
      3: use 10 ~ 13 Channel
      4: use 14 Channel
      5: use 1 ~ 14 Channel
      6: use 3 ~ 9 Channel
      7: use 5 ~ 13 Channel
      31: use 1 ~ 14 Channel (ch1-11:active scan, ch12-14 passive scan)
@> CountryRegionABand=value
   value
      0: use 36, 40, 44, 48, 52, 56, 60, 64, 149, 153, 157, 161, 165 Channel
      1: use 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, 140 Channel
      2: use 36, 40, 44, 48, 52, 56, 60, 64 Channel
      3: use 52, 56, 60, 64, 149, 153, 157, 161 Channel
      4: use 149, 153, 157, 161, 165 Channel
      5: use 149, 153, 157, 161 Channel
      6: use 36, 40, 44, 48 Channel
      7: use 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, 140, 149, 153, 157, 161, 165 Channel
      8: use 52, 56, 60, 64 Channel
      9: use 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 132, 136, 140, 149, 153, 157, 161, 165 Channel
      10: use 36, 40, 44, 48, 149, 153, 157, 161, 165 Channel
      11: use 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 120, 149, 153, 157, 161 Channel
@> CountryCode=value
   value
      AG, AR, AW, AU, AT, BS, BB, BM, BR, BE, BG, CA, KY, CL, CN, CO, CR, CY, CZ, DK, DO, EC, SV, FI, FR, DE,
      GR, GU, GT, HT, HN, HK, HU, IS, IN, ID, IE, IL, IT, JP, JO, LV, LI, LT, LU, MY, MT, MA, MX, NL, NZ, NO,
      PE, PT, PL, RO, RU, SA, CS, SG, SK, SI, ZA, KR, ES, SE, CH, TW, TR, GB, UA, AE, US, VE
      "" => using default setting: 2.4 G - ch 1~11; 5G - ch 52~64, 100~140, 149~165
@> SSID=value
   value
      0~z, 1~32 ascii characters.
@> WirelessMode=value
   value
      0: legacy 11b/g mixed
      1: legacy 11B only
      2: legacy 11A only         //Not support in RfIcType=1(id=RFIC_5225) and RfIcType=2(id=RFIC_5325)
      3: legacy 11a/b/g mixed     //Not support in RfIcType=1(id=RFIC_5225) and RfIcType=2(id=RFIC_5325)
      4: legacy 11G only
      5: 11ABGN mixed
      6: 11N only
      7: 11GN mixed
      8: 11AN mixed
      9: 11BGN mixed
      10: 11AGN mixed
@> Channel=value
   value
      depends on CountryRegion or CountryRegionABand
@> BGProtection=value
   value
      0: Auto
      1: Always on
      2: Always off
@> TxPreamble=value
     value
      0:Preamble Long
      1:Preamble Short
      2:Auto
@> RTSThreshold=value
   value
      1~2347
@> FragThreshold=value
   value
      256~2346
@> TxBurst=value
   value
      0: Disable
      1: Enable
@> NetworkType=value
   value
      Infra: infrastructure mode
          Adhoc: adhoc mode
@> AuthMode=value
   value
      OPEN       For open system
      SHARED        For shared key system
      WEPAUTO     Auto switch between OPEN and SHARED
      WPAPSK      For WPA pre-shared key  (Infra)
      WPA2PSK     For WPA2 pre-shared key (Infra)
      WPANONE      For WPA pre-shared key  (Adhoc)
      WPA         Use WPA-Supplicant
      WPA2        Use WPA-Supplicant
@> EncrypType=value
   value
      NONE      For AuthMode=OPEN
      WEP         For AuthMode=OPEN or AuthMode=SHARED
      TKIP      For AuthMode=WPAPSK or WPA2PSK
      AES         For AuthMode=WPAPSK or WPA2PSK
@> DefaultKeyID=value
   value
      1~4
@> Key1=value
    Key2=value
    Key3=value
    Key4=value
   value
      10 or 26 hexadecimal characters eg: 012345678
        5 or 13 ascii characters eg: passd
    (usage : "iwpriv" only)
@> Key1Type=vaule
    Key2Type=value
    Key3Type=vaule
    Key4Type=vaule
    value
      0   hexadecimal type
      1   assic type
    (usage : reading profile only)
@> Key1Str=value
    Key2Str=value
    Key3Str=vaule
    Key4Str=vaule
    value
      10 or 26 characters (key type=0)
      5 or 13 characters  (key type=1)
@> WPAPSK=value
   value
      8~63 ASCII        or
      64 HEX characters
@> WmmCapable=value
   value
      0: Disable WMM
      1: Enable WMM
@> PSMode=value
    value
       CAM             Constantly Awake Mode
      Max_PSP          Max Power Savings
      Fast_PSP      Power Save Mode
@> FastRoaming=value
   value
      0            Disabled
      1            Enabled
@> RoamThreshold=value
   value
      Positive Interger(dBm)
@> HT_RDG=value
   value
      0            Disabled
      1            Enabled
@> HT_EXTCHA=value (Extended Channel Switch Announcement)
   value
      0            Below
      1             Above
@> HT_OpMode=value
   value
      0            HT mixed format
      1            HT greenfield format
@> HT_MpduDensity=value
   value (based on 802.11n D2.0)
      0: no restriction
      1: 1/4 £gs
      2: 1/2 £gs
      3: 1 £gs
      4: 2 £gs
      5: 4 £gs
      6: 8 £gs
      7: 16 £gs
@> HT_BW=value
   value
      0            20MHz
      1            40MHz
@> HT_AutoBA=value
   value
      0            Disabled
      1            Enabled
@> HT_BADecline
   value
      0            Disabled
      1             Enabled <Reject BA request from AP>
@> HT_AMSDU=value
   value
      0            Disabled
      1            Enabled
@> HT_BAWinSize=value
   value
      1 ~ 64
@> HT_GI=value
   value
      0            long GI
      1            short GI
@> HT_MCS=value
   value
      0 ~ 15
      33: auto
@> HT_MIMOPSMode=value
      0            Static SM Power Save Mode
      1            Dynamic SM Power Save Mode
      2            Reserved
      3            SM enabled
   (not fully support yet)
@> EthConvertMode=value
   value
      dongle
      clone
      hybrid
@> EthCloneMac=value
   value
      xx:xx:xx:xx:xx:xx
@> IEEE80211H=value
   value
      0            Disabled
      1            Enabled
@> TGnWifiTest=value
   value
      0            Disabled
      1            Enabled
@> WirelessEvent=value
   value
      0            Disabled
      1            Enabled <send custom wireless event>
@> MeshId=value
   value
      Length 1~32 ascii characters
@> MeshAutoLink=value
   value
      0            Disabled
      1            Enabled
@> MeshAuthMode=value
   value
@> MeshEncrypType=value
   value
      NONE      For MeshAuthMode=OPEN
      WEP         For MeshAuthMode=OPEN
      TKIP      For MeshAuthMode=WPANONE
      AES         For MeshAuthMode=WPANONE
@> MeshWPAKEY=value
   value
      8~63 ASCII        or
      64 HEX characters
@> MeshDefaultkey=value
   value
      1~4
@> MeshWEPKEY=value
   value
      10 or 26 characters
      5 or 13 characters
@> CarrierDetect=value
   value
      0            Disabled
      1            Enabled
MORE INFORMATION
If you want for rt2870 driver to auto-load at boot time:
A) choose ra0 for first RT2870 WLAN card, ra1 for second RT2870 WLAN card, etc.
B) create(edit) 'ifcfg-ra0' file in /etc/sysconfig/network-scripts/,
   edit( or add the line) in /etc/modules.conf:
       alias ra0 rt2870sta
C) edit(create) the file /etc/sysconfig/network-scripts/ifcfg-ra0
   DEVICE='ra0'
   ONBOOT='yes'
NOTE:
   if you use dhcp, add this line too .
    BOOTPROTO='dhcp'
*D) To ease the Default Gateway setting,
    add the line
    GATEWAY=x.x.x.x
Is this something I can use/do?
« Last Edit: October 13, 2014, 11:41:19 pm by VinDSL, Reason: Added spoiler tags »
« Reply #34 on: October 14, 2014, 04:30:04 am »
plug in the adapter, then post the output from:
lsusb
Offline kskarda
« Reply #35 on: October 14, 2014, 07:33:07 am »
Okay, here it is:
Bus 001 Device 003: ID 04f2:b367 Chicony Electronics Co., Ltd
Bus 001 Device 002: ID 083a:a701 Accton Technology Corp. SMCWUSBS-N3 EZ Connect N Wireless Adapter [Ralink RT3070]
Bust 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
« Reply #36 on: October 14, 2014, 11:27:12 am »
OK, can you post the output from:
sudo lshw -C network
rfkill list
iwlist scanning
iwconfig
lsmod
Offline kskarda
« Reply #37 on: October 16, 2014, 01:18:23 am »
Okay, it's a long set out of outputs...
somjit@somjit-AOD270 ~ $ sudo lshw -C network
[sudo] password for somjit:
  *-network
       product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
       physical id: 0
       bus info: pci@0000:01:00.0
       logical name: eth0
       version: 05
       serial: 04:7d:7b:df:4d:01
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl_nic/rtl8105e-1.fw latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:45 ioport:4000(size=256) memory:c0004000-c0004fff memory:c0000000-c0003fff
  *-network
       product: BCM4313 802.11bgn Wireless Network Adapter
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:02:00.0
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: driver=bcma-pci-bridge latency=0
       resources: irq:17 memory:c4000000-c4003fff
  *-network:0
       physical id: 1
       logical name: wlan0
       serial: 84:4b:f5:7c:14:75
       configuration: broadcast=yes driver=brcmsmac driverversion=3.13.0-29-generic firmware=610.812 ip=192.168.1.118 link=yes multicast=yes wireless=IEEE 802.11bgn
  *-network:1
       physical id: 2
       bus info: usb@1:2
       logical name: wlan1
       serial: 00:26:f3:62:d4:fc
       configuration: broadcast=yes driver=rt2800usb driverversion=3.13.0-29-generic firmware=0.29 ip=192.168.1.105 link=yes multicast=yes wireless=IEEE 802.11bgn
somjit@somjit-AOD270 ~ $ rfkill list
0: phy0: Wireless LAN
   Soft blocked: no
   Hard blocked: no
1: acer-wireless: Wireless LAN
   Soft blocked: no
   Hard blocked: no
2: phy1: Wireless LAN
   Soft blocked: no
   Hard blocked: no
somjit@somjit-AOD270 ~ $ iwlist scanning
wlan0     Scan completed :
          Cell 01 - Address: E8:94:F6:D6:CE:E1
                    Channel:8
                    Frequency:2.447 GHz (Channel 8)
                    Quality=50/70  Signal level=-60 dBm
                    Encryption key:on
                    ESSID:"Pentecross"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s
                              18 Mb/s; 36 Mb/s; 54 Mb/s
                    Bit Rates:6 Mb/s; 12 Mb/s; 24 Mb/s; 48 Mb/s
                    Mode:Master
                    Extra:tsf=0000004b9c3d4b73
                    Extra: Last beacon: 33276ms ago
                    IE: Unknown: 000A50656E746563726F7373
                    IE: Unknown: 010882848B961224486C
                    IE: Unknown: 030108
                    IE: Unknown: 2A0104
                    IE: Unknown: 32040C183060
                    IE: Unknown: 2D1AEE1117FFFF0000010000000000000000000000000C0000000000
                    IE: Unknown: 3D1608070600000000000000000000000000000000000000
                    IE: Unknown: 3E0100
                    IE: WPA Version 1
                        Group Cipher : CCMP
                        Pairwise Ciphers (1) : CCMP
                        Group Cipher : CCMP
                    IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00
                    IE: Unknown: 4A0E14000A002C01C800140005001900
                    IE: Unknown: 7F0101
                    IE: Unknown: DD07000C4304000000
                    IE: Unknown: 0706555300010B10
eth0      Interface doesn't support scanning.
wlan1     Scan completed :
                    Channel:8
                    Quality=38/70  Signal level=-72 dBm
                    Encryption key:on
                    ESSID:"Pentecross"
                    Mode:Master
                    Extra:tsf=0000004b9cb79c44
                    Extra: Last beacon: 24844ms ago
                    IE: Unknown: 030108
                    IE: Unknown: 2A0104
                    IE: Unknown: 3E0100
                    IE: WPA Version 1
                        Group Cipher : CCMP
                        Group Cipher : CCMP
                    IE: Unknown: 7F0101
          Cell 02 - Address: 10:7B:EF:A8:BE:44
                    Channel:2
                    Frequency:2.417 GHz (Channel 2)
                    Quality=20/70  Signal level=-90 dBm
                    Encryption key:on
                    ESSID:"Ass"
                    Mode:Master
                    Extra:tsf=0000000eee72ae82
                    IE: Unknown: 0003417373
                    IE: Unknown: 030102
                    IE: Unknown: 2A0104
                    IE: Unknown: 2D1A6E1117FF000000010000000000000000000000000C0000000000
                    IE: Unknown: 3D1602000600000000000000000000000000000000000000
                    IE: Unknown: 3E0100
                        Group Cipher : TKIP
                        Pairwise Ciphers (2) : TKIP CCMP
                    IE: Unknown: 7F0101
                    IE: Unknown: 0706545720010B10
                    IE: Unknown: DD9D0050F204104A0001101044000102103B00010310470010BC329E001DD811B28601107BEFA8BE441021001852616C696E6B20546563686E6F6C6F67792C20436F72702E1023001C52616C696E6B20576972656C6573732041636365737320506F696E74102400065254323836301042000831323334353637381054000800060050F20400011011000952616C696E6B415053100800020084103C000100
somjit@somjit-AOD270 ~ $ iwconfig
wlan0     IEEE 802.11bgn  ESSID:"Pentecross"
          Mode:Managed  Frequency:2.447 GHz  Access Point: E8:94:F6:D6:CE:E1
          Bit Rate=72.2 Mb/s   Tx-Power=27 dBm
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
          Link Quality=55/70  Signal level=-55 dBm
          Tx excessive retries:0  Invalid misc:8   Missed beacon:0
eth0      no wireless extensions.
wlan1     IEEE 802.11bgn  ESSID:"Pentecross"
          Bit Rate=60 Mb/s   Tx-Power=27 dBm
          Power Management:on
          Link Quality=36/70  Signal level=-74 dBm
          Tx excessive retries:2  Invalid misc:10   Missed beacon:0
somjit@somjit-AOD270 ~ $ lsmod
Module                  Size  Used by
ctr                    12905  4
ccm                    17496  4
rfcomm                 53664  0
bnep                   18895  2
bluetooth             342263  10 bnep,rfcomm
snd_hda_codec_realtek    51029  1
snd_hda_codec_hdmi     45303  1
snd_hda_intel          42730  3
snd_hda_codec         164067  3 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_intel
snd_hwdep              13272  1 snd_hda_codec
snd_pcm                85501  3 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel
rt2800usb              26581  0
rt2x00usb              20041  1 rt2800usb
snd_page_alloc         14230  2 snd_pcm,snd_hda_intel
acer_wmi               31735  0
snd_seq_midi           13132  0
sparse_keymap          13708  1 acer_wmi
snd_seq_midi_event     14475  1 snd_seq_midi
snd_rawmidi            25135  1 snd_seq_midi
rt2800lib              83150  1 rt2800usb
uvcvideo               71309  0
rt2x00lib              48886  3 rt2x00usb,rt2800lib,rt2800usb
videobuf2_vmalloc      13048  1 uvcvideo
videobuf2_memops       13170  1 videobuf2_vmalloc
crc_ccitt              12627  1 rt2800lib
videobuf2_core         39258  1 uvcvideo
videodev              108503  2 uvcvideo,videobuf2_core
snd_seq                55383  2 snd_seq_midi_event,snd_seq_midi
coretemp               13195  0
snd_seq_device         14137  3 snd_seq,snd_rawmidi,snd_seq_midi
snd_timer              28584  2 snd_pcm,snd_seq
parport_pc             31981  0
joydev                 17101  0
ppdev                  17391  0
serio_raw              13230  0
arc4                   12536  4
gma500_gfx            168634  3
brcmsmac              529837  0
snd                    60871  17 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec,snd_hda_intel,snd_seq_device,snd_seq_midi
drm_kms_helper         46907  1 gma500_gfx
rtsx_pci_ms            17807  0
cordic                 12518  1 brcmsmac
memstick               16174  1 rtsx_pci_ms
drm                   243792  4 drm_kms_helper,gma500_gfx
soundcore              12600  1 snd
brcmutil               15066  1 brcmsmac
lpc_ich                16864  0
bcma                   42043  2 brcmsmac
i2c_algo_bit           13197  1 gma500_gfx
mac80211              546051  4 brcmsmac,rt2x00lib,rt2x00usb,rt2800lib
wmi                    18673  1 acer_wmi
video                  18903  2 acer_wmi,gma500_gfx
mac_hid                13037  0
cfg80211              409394  3 brcmsmac,mac80211,rt2x00lib
lp                     13299  0
parport                40836  3 lp,ppdev,parport_pc
btrfs                 822702  0
xor                    26221  1 btrfs
raid6_pq               97455  1 btrfs
libcrc32c              12543  1 btrfs
rtsx_pci_sdmmc         22693  0
r8169                  61562  0
rtsx_pci               43796  2 rtsx_pci_ms,rtsx_pci_sdmmc
ahci                   25579  2
psmouse                91033  0
libahci                26754  1 ahci
mii                    13654  1 r8169
« Last Edit: October 16, 2014, 01:25:43 am by VinDSL, Reason: Added spoiler tags »
« Reply #38 on: October 16, 2014, 08:19:42 am »
run:
sudo gedit /etc/modprobe.d/blacklist.conf
when a file opens that already contains some stuff, add a single NEW line at the bottom that reads
blacklist brcmsmac
SAVE the file .. and reboot
Now post the output from:
sudo iwlist scanning
Offline kskarda
« Reply #39 on: October 16, 2014, 08:37:18 pm »
Okay, next output round... (by the way, thanks again... we're way above my head now, and I appreciate the time you've put into solving this)
  *-network
       physical id: 0
       logical name: eth0
       version: 05
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
  *-network
       physical id: 0
       version: 01
       width: 64 bits
       clock: 33MHz
  *-network:0
       physical id: 1
       logical name: wlan0
  *-network:1
       physical id: 2
       bus info: usb@1:2
       logical name: wlan1
somjit@somjit-AOD270 ~ $ sudo iwlist scanning
                    Channel:8
                    Quality=52/70  Signal level=-58 dBm
                    Encryption key:on
                    ESSID:"Pentecross"
                    Mode:Master
                    Extra:tsf=0000005c0c6ddcfe
                    Extra: Last beacon: 76ms ago
                    IE: Unknown: 030108
                    IE: Unknown: 2A0104
                    IE: Unknown: 3E0100
                    IE: WPA Version 1
                        Group Cipher : CCMP
                        Group Cipher : CCMP
                    IE: Unknown: 7F0101
          Cell 02 - Address: 00:4F:62:2B:56:77
                    Channel:1
                    Frequency:2.412 GHz (Channel 1)
                    Quality=23/70  Signal level=-87 dBm
                    Encryption key:off
                    ESSID:"SP_Coffee_Resort"
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
                              9 Mb/s; 12 Mb/s; 18 Mb/s
                    Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
                    Mode:Master
                    Extra:tsf=0000005c0aa0d19a
                    Extra: Last beacon: 1908ms ago
                    IE: Unknown: 001053505F436F666665655F5265736F7274
                    IE: Unknown: 010882848B968C9298A4
                    IE: Unknown: 030101
                    IE: Unknown: 0509000100080880000242
                    IE: Unknown: 2A0104
                    IE: Unknown: 3204B0C8E0EC
                    IE: Unknown: DD0700E04C01020300
          Cell 03 - Address: 00:04:ED:E8:29:E6
                    Channel:1
                    Quality=24/70  Signal level=-86 dBm
                    Encryption key:on
                    ESSID:"i Phone"
                    Mode:Master
                    Extra:tsf=0000004567085079
                    IE: Unknown: 0007692050686F6E65
                    IE: Unknown: 030101
                    IE: Unknown: 2A0104
                    IE: Unknown: 3D1601000400000000000000000000000000000000000000
                    IE: Unknown: 3E0100
                    IE: WPA Version 1
                        Group Cipher : TKIP
                    IE: Unknown: 7F0101
          Cell 04 - Address: 10:7B:EF:A8:BE:44
                    Channel:2
                    Quality=33/70  Signal level=-77 dBm
                    Encryption key:on
                    ESSID:"Ass"
                    Mode:Master
                    Extra:tsf=0000001f5e2f1de9
                    IE: Unknown: 030102
                    IE: Unknown: 2A0104
                    IE: Unknown: 3D1602050600000000000000000000000000000000000000
                    IE: Unknown: 3E0100
                        Group Cipher : TKIP
                    IE: Unknown: 7F0101
          Cell 05 - Address: 00:4F:81:07:37:10
                    Channel:7
                    Frequency:2.442 GHz (Channel 7)
                    Quality=26/70  Signal level=-84 dBm
                    Encryption key:off
                    ESSID:"SP_Palad"
                    Mode:Master
                    Extra:tsf=0000000f109aa372
                    Extra: Last beacon: 196ms ago
                    IE: Unknown: 000853505F50616C6164
                    IE: Unknown: 030107
                    IE: Unknown: 0706534120010E14
                    IE: Unknown: 33082001020304050607
                    IE: Unknown: 33082105060708090A0B
                    IE: Unknown: DD270050F204104A0001101044000102104700102880288028801880A880004F81073710103C000101
                    IE: Unknown: 05050001005001
                    IE: Unknown: 2A0104
                    IE: Unknown: 2D1AEE1117FF000000010000000000000000000000000C0000000000
                    IE: Unknown: 3D1607050500000000000000000000000000000000000000
                    IE: Unknown: 7F0101
                    IE: Unknown: 0B0502001E127A
                    IE: Unknown: DD1E00904C33EE1117FF000000010000000000000000000000000C0000000000
                    IE: Unknown: DD1A00904C3407050500000000000000000000000000000000000000
                    IE: Unknown: DD07000C4307000000
          Cell 06 - Address: B0:B2:DC:DC:46:FC
                    Channel:6
                    Frequency:2.437 GHz (Channel 6)
                    Quality=21/70  Signal level=-89 dBm
                    Encryption key:on
                    ESSID:"Noppakrit"
                    Mode:Master
                    Extra:tsf=0000005c0bf57164
                    Extra: Last beacon: 980ms ago
                    IE: Unknown: 00094E6F7070616B726974
                    IE: Unknown: 030106
                    IE: Unknown: 0706465220010D14
                    IE: Unknown: 050400010008
                    IE: Unknown: DD310050F204104A0001101044000102104700102880288028801880A880B0B2DCDC46FC103C0001011049000600372A000120
                    IE: Unknown: 2A0100
                    IE: Unknown: 3D1606000600000000000000000000000000000000000000
                    IE: Unknown: 7F0101
                        Group Cipher : CCMP
                    IE: Unknown: 0B05020007127A
          Cell 07 - Address: 90:F6:52:DB:4D:16
                    Channel:2
                    Quality=22/70  Signal level=-88 dBm
                    Encryption key:on
                    ESSID:"Suthep"
                    Mode:Master
                    Extra:tsf=0000005c0ca15152
                    Extra: Last beacon: 1820ms ago
                    IE: Unknown: 0006537574686570
                    IE: Unknown: 030102
                    IE: Unknown: 0706544800010D14
                    IE: Unknown: 050400010000
                    IE: Unknown: 2A0104
                    IE: WPA Version 1
                        Group Cipher : TKIP
                        Group Cipher : TKIP
                    Channel:8
                    Encryption key:on
                    ESSID:"Pentecross"
                    Mode:Master
                    Extra:tsf=0000005c0c9c3863
                    Extra: Last beacon: 164ms ago
                    IE: Unknown: 030108
                    IE: Unknown: 2A0104
                    IE: Unknown: 3E0100
                    IE: WPA Version 1
                        Group Cipher : CCMP
                        Group Cipher : CCMP
                    IE: Unknown: 7F0101
                    Channel:2
                    Quality=18/70  Signal level=-92 dBm
                    Encryption key:on
                    ESSID:"Ass"
                    Mode:Master
                    Extra:tsf=0000001f5e514a47
                    Extra: Last beacon: 2964ms ago
                    IE: Unknown: 030102
                    IE: Unknown: 2A0104
                    IE: Unknown: 3E0100
                        Group Cipher : TKIP
                    IE: Unknown: 7F0101
« Reply #40 on: October 17, 2014, 01:24:11 pm »
Try running:
sudo update-initramfs -u
then REBOOT.
Now what's the output from:
Offline kskarda
« Reply #41 on: October 25, 2014, 07:01:30 am »
I apologize, my husband has given up on Peppermint now. He's ready to go back to Windows, so I am going to try to find some other last minute solution. I'm sure it is not Windows only that can use the aspire one's wireless driver. Thanks so much for your help, and sorry we couldn't bring this problem to a conclusion.
« Reply #42 on: October 26, 2014, 08:45:52 am »
I don't know if this will help solve the mystery of kskarda's problems, but she and her husband may not be alone concerning diver issues that are affecting some computers running either Arch or Ubuntu-based distributions.  Might there be an issue about Xorg affecting divers?
Admittedly, I don't know a thing about Xorg, so feel free to take what I speculating upon here with a grain of salt!
Of course, you guys know me.  I tend to blame everything on that new Aura feature of Chrome and Chromium.  I did notice that her own personal computer has no problem with Elementary OS, and the default browser of Elementary is Midori and not Chromium.
So now I'm speculating her husband's computer's problem is either with Xorg or Aura, and maybe there's nothing anyone here can do about it at this time.  :(
« Last Edit: October 26, 2014, 12:17:46 pm by perknh »
« Reply #43 on: October 26, 2014, 11:14:01 am »
Can't for the life of me see how Xorg would influence wireless ?
Xorg is concerned with graphics and input .. it has nothing to do with networking/wireless, in fact my VPS hasn't got Xorg installed (14.04 server edition, so no GUI ddesktop) yet networking/wireless work fine.
Oh, and what's with the video ? .. I wasted nearly 12 minutes of my life waiting for him to mention a connection, but he doesn't AT ALL .. the video is TOTALLY superfluous and takes MUCH longer than 1:45 to watch  :-\
« Reply #44 on: October 26, 2014, 12:16:13 pm »
I wasted nearly 12 minutes of my life waiting for him to mention a connection, but he doesn't AT ALL .. the video is TOTALLY superfluous and takes MUCH longer than 1:45 to watch  :-\ -- PCNetSpec
Sorry, PCNetSpec.
Xorg was mentioned in the first minute plus as being the reason why Matthew Moore wasn't using Arch or Ubuntu -- nothing more.  I'll remove the link.
My apologies.  :-[
perknh
« Last Edit: October 26, 2014, 04:10:18 pm by perknh »
