Author Topic: After installing, the GRUB screen shows up  (Read 15089 times)
Offline silver2049
  • Peppermint version(s): Hopefully 5 by end of month
Re: After installing, the GRUB screen shows up
« Reply #60 on: January 21, 2015, 02:18:29 pm »
I left the original one alone for your question about the 2 Linux partitions, and no unless switch the boot order, or boot from BIOS
« Reply #61 on: January 21, 2015, 02:40:06 pm »
Try this....
sudo mount /dev/sdd5 /mntthen
for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; donethen
sudo chroot /mntthen
grub-install --recheck /dev/sddthen
update-grubnow close the terminal and shut down the PC
Now try booting to the external hard drive by selecting it as the first boot device
Offline silver2049
« Reply #62 on: January 21, 2015, 08:10:30 pm »
I had to shutdown my laptop earlier but when I ran
sudo fdisk -l just to check if anything changed, i noticed sdd changed to sdc so what do I do now?
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
256 heads, 63 sectors/track, 121126 cylinders, total 1953525168 sectors
Disk identifier: 0xd9d7d1a1
/dev/sda1               1  4294967295  2147483647+  ee  GPT
Partition 1 does not start on physical sector boundary.
Disk /dev/sdb: 15.5 GB, 15512174592 bytes
32 heads, 63 sectors/track, 15028 cylinders, total 30297216 sectors
Disk identifier: 0x7bae5e37
/dev/sdb1   *          63    30296447    15148192+   c  W95 FAT32 (LBA)
Disk /dev/sdc: 1000.2 GB, 1000170586112 bytes
255 heads, 63 sectors/track, 121597 cylinders, total 1953458176 sectors
Disk identifier: 0x50c5766c
/dev/sdc1      1733928958  1953456127   109763585    5  Extended
/dev/sdc2   *        2048    39063551    19530752   83  Linux
/dev/sdc3        39063552  1733926911   847431680   83  Linux
/dev/sdc5      1753458688  1953456127    99998720   82  Linux swap / Solaris
/dev/sdc6      1733928960  1753458687     9764864   82  Linux swap / Solaris
Partition table entries are not in disk order
« Last Edit: January 22, 2015, 12:49:06 am by silver2049 »
« Reply #63 on: January 22, 2015, 02:05:17 am »
sudo mount /dev/sdc5 /mntthen
grub-install --recheck /dev/sdcthen
Offline silver2049
« Reply #64 on: January 22, 2015, 05:11:26 am »
/dev/sdc5 looks like swapspace - not mounted
mount: you must specify the filesystem type
peppermint@peppermint ~ $ for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; done
mount: mount point /mnt/dev does not exist
mount: mount point /mnt/dev/pts does not exist
mount: mount point /mnt/proc does not exist
mount: mount point /mnt/sys does not exist
mount: mount point /mnt/run does not exist
peppermint@peppermint ~ $ sudo chroot /mnt
chroot: failed to run command ‘/bin/bash’: No such file or directory
peppermint@peppermint ~ $ grub-install --recheck /dev/sdc
Installing for i386-pc platform.
grub-install: error: cannot open directory `/boot/grub/i386-pc': No such file or directory.
peppermint@peppermint ~ $ update-grub
grub-mkconfig: You must run this as root
peppermint@peppermint ~ $ sudo update-grub
/usr/sbin/grub-probe: error: failed to get canonical path of `/cow'.
Is it supposed to give these outputs?
« Reply #65 on: January 22, 2015, 05:28:41 am »
My apologies, I made a mistake
sudo mount /dev/sdc3 /mntthen
Offline silver2049
« Reply #66 on: January 22, 2015, 05:54:27 am »
peppermint / # grub-install --recheck /dev/sdc
Installing for x86_64-efi platform.
grub-install: error: cannot find EFI directory.
Is this supposed to happen?
« Reply #67 on: January 22, 2015, 06:54:42 am »
Have you enabled CSM in the BIOS ?
Offline silver2049
« Reply #68 on: January 22, 2015, 10:09:03 am »
When I posted it, no. So I enabled it and it still showed the same error message.
« Reply #69 on: January 22, 2015, 10:53:49 am »
Now that the NTFS partition is missing on that external drive, so you've lost anything from indows that was stored on it .. what I'd do if I were you would be
a) delete ALL partitions on the drive
b) install Peppermint again, creating the 2 partitions as before .. and making SURE to install the bootloader to the root of the external HDD (NOT the internal HDD)
but do ALL this with CSM enabled.
Offline silver2049
« Reply #70 on: January 22, 2015, 07:22:49 pm »
I did it with CSM enabled, I'm still getting all the errors
« Reply #71 on: January 23, 2015, 04:52:25 am »
Can you try to  be more descriptive in your responses .. please remember we can't know what you've just done or what the errors are unless you tell us.
What errors ?
and what are you doing when you get the errors ?
The more info you give the better.
What's the make/model of this laptop ?
OK, I think what's happening here is that Peppermint/GRUB is being installed in EFI mode, but for some reason the EFI partition is being formatted as something other than VFAT (FAT32) .. this explains the 2 "linux" partitions, when you only created one.
So...
We need to create an EFI boot partition before the installation.
First set CSM back to disabled (as that will stop Windows from booting).
Now boot to the LiveCD/LiveUSB .. fire up gparted, and delete ALL partitions on the external HDD .. then as described here:
https://help.ubuntu.com/community/UEFI#Creating_an_EFI_partition
in Gparted create a single partition with these attributes
New size = 200MB
Created as = Primary Partition
File system = FAT32
Label = EFI
Apply that, then once the partition is created, right click on it and select "Manage Flags" and put a tick in the "boot" box.
Close Gparted and fire the installer by clicking on the "Install Peppermint" desktop icon.
As before when you get to the "where to put Peppermint" section choose "Something else" and create 2 partitions in the unparttioned space.
(from here I'm assuming the external HDD is /dev/sdc)
first partition:-
Size = all of the free space except gor 10GB
Type = Primary
Filesystem = EXT4
Mountpoint = /
Second partition
Size = the rest of the free space (approx 10GB)
Type= Logical
Filesystem = Swap
Now at the bottom of the screen make sure the bootloader is placed on
/dev/sdc
« Last Edit: January 23, 2015, 06:18:58 am by PCNetSpec »
Offline silver2049
« Reply #72 on: January 23, 2015, 05:22:00 am »
First of all, I repartitioned my external HDD with CSM enabled just as you asked, then reinstalled Peppermint the way you wanted me to. Then when I restart the computer the GRUB screen shows up again. So I open a live session and do the commands like you told me:
sudo chroot /mnt
update-grub
but then i still get the same error from last time where it says:
My laptop model is the ASUS X750JA.
http://www.asus.com/Notebooks_Ultrabooks/X750JA/specifications/
Is the 1 TB HDD, Super-Multi DVD, no Bluetooth version
« Reply #73 on: January 23, 2015, 06:15:32 am »
Can you see the edit to my last posting :)
Be SURE to change CSM back to disable BEFORE installation ;)
Might also be a good idea to have pre-created a "Boot Repair" LiveUSB just in case:
http://sourceforge.net/p/boot-repair-cd/home/Home/
The only other thing I can think of if that doesn't work is to change the partition table to GPT before doing what's in the edit to my last posting.
I haven't really had that much experience with UEFI and dual boot .. particularly on an external HDD, and not wanting to risk the Windows installation.
« Last Edit: January 23, 2015, 06:40:12 am by PCNetSpec »
Offline silver2049
« Reply #74 on: January 23, 2015, 09:38:18 am »
I give up, it still doesn't work, I'm just gonna download another distro
