Author Topic: After installing, the GRUB screen shows up  (Read 14128 times)
Offline silver2049
  • Peppermint version(s): Hopefully 5 by end of month
« on: September 24, 2014, 01:36:48 pm »
I installed Peppermint OS on to an external hard drive, using a Live USB but when I  tried to boot it after finishing the installation with no problems, it showed the GRUB prompt and I'm not sure what I can do now to fix it.
Re: After installing, the GRUB screen shows up
« Reply #1 on: September 24, 2014, 02:17:55 pm »
What is being displayed by the "GRUB screen" ?
What is on the internal HDD ? .. ie. was this a dual boot setup with Windows on the internal drive and Peppermint on the external drive ?
Can you also boot to the Peppermint LiveUSB and post the output from running these 2 commands in a terminal:
sudo fdisk -land
sudo blkid
« Last Edit: September 24, 2014, 02:21:03 pm by PCNetSpec »
Offline willowdancer
  • Peppermint version(s): 5
« Reply #2 on: November 19, 2014, 02:27:19 pm »
sudo fdisk -land
sudo blkid
Hey im also having the same problem the internal hard-drive just has peppermint os 5 i installed it from live usb i deleted windows also grub is asking for a bash command the results you asked for
Disk /dev/sda: 750.2 GB, 750156374016 bytes
255 heads, 63 sectors/track, 91201 cylinders, total 1465149168 sectors
Disk identifier: 0x00000000
/dev/sda1               1  1465149167   732574583+  ee  GPT
Partition 1 does not start on physical sector boundary.
Disk /dev/sdb: 8166 MB, 8166703104 bytes
256 heads, 63 sectors/track, 989 cylinders, total 15950592 sectors
Disk identifier: 0xc3072e18
/dev/loop0: TYPE="squashfs"
/dev/sda1: UUID="EE44-9BB9" TYPE="vfat"
/dev/sda2: UUID="455ebb63-1542-4ad1-9733-39136dbe346d" TYPE="ext2"
/dev/sda3: UUID="6e408e66-4605-4fdb-8878-4914655a1572" TYPE="crypto_LUKS"
/dev/sdb1: UUID="4C3E-AE78" TYPE="vfat
« Reply #3 on: November 19, 2014, 02:57:35 pm »
@willowdancer
This is still an active topic (not marked as solved /closed / abandoned) so please start your own topic.
If I reply to you on this topic and my reply is different from what I'd say to the OP it would become rather confusing.
Offline silver2049
« Reply #4 on: January 18, 2015, 10:25:27 am »
Sorry for the REALLY Late reply, i thought i would be notified when i got a reply.
Anyways this is what showed up when i ran sudo fdisk -l :
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
256 heads, 63 sectors/track, 121126 cylinders, total 1953525168 sectors
Disk identifier: 0xd9d7d1a1
/dev/sda1               1  4294967295  2147483647+  ee  GPT
Disk /dev/sdb: 15.5 GB, 15512174592 bytes
32 heads, 63 sectors/track, 15028 cylinders, total 30297216 sectors
Disk identifier: 0x7bae5e37
/dev/sdb1   *          63    30296447    15148192+   c  W95 FAT32 (LBA)
Disk /dev/sdc: 1000.2 GB, 1000170586112 bytes
255 heads, 63 sectors/track, 121597 cylinders, total 1953458176 sectors
Disk identifier: 0x50c5766c
/dev/sdc1            2048     2000895      999424   82  Linux swap / Solaris
/dev/sdc2         2000896  1953454079   975726592    7  HPFS/NTFS/exFAT
...and when i ran sudo blkid:
/dev/sda1: LABEL="SYSTEM" UUID="2676-E74C" TYPE="vfat"
/dev/sda2: LABEL="Recovery" UUID="C4BC3E5BBC3E47E6" TYPE="ntfs"
/dev/sda4: LABEL="OS" UUID="66F44183F4415709" TYPE="ntfs"
/dev/sda5: UUID="86DCB554DCB53F6D" TYPE="ntfs"
/dev/sda7: LABEL="Restore" UUID="FC12449412445634" TYPE="ntfs"
/dev/sdb1: LABEL="KINGSTON" UUID="7CDB-709D" TYPE="vfat"
/dev/sdc1: UUID="5e108c4c-f030-4339-8d56-16bb8baa4b72" TYPE="swap"
/dev/sdc2: LABEL="PASSPORT" UUID="049CB5B69CB5A29A" TYPE="ntfs"
Offline silver2049
« Reply #5 on: January 18, 2015, 10:26:27 am »
Also, my setup was Windows on my internal, Peppermint on my external
« Reply #6 on: January 18, 2015, 03:34:28 pm »
Are you still able to boot Windows ?
Offline silver2049
« Reply #7 on: January 18, 2015, 03:36:53 pm »
Yes
« Reply #8 on: January 18, 2015, 04:22:12 pm »
Hmm....
I take it your external HDD is the one with a partition labelled "PASSPORT" .. so I'm guessing it's a WD Passport 1TB ?
If so, then it doesn't contain a Linux partition, just a swap partition and an NTFS partition
Can you install gdisk:
sudo apt-get install gdiskthen post the output from:
sudo gdisk -l /dev/sda
Offline silver2049
« Reply #9 on: January 18, 2015, 04:32:07 pm »
Wait sda or sdc?
« Reply #10 on: January 18, 2015, 04:44:00 pm »
sda
I want to see the partition layout on the internal HDD .. but it has a GPT partition table so fdisk can't read it .. gdisk can.
I'm just trying to figure out what happened to the Peppermint installation as it appears to be missing  :-\
Offline silver2049
« Reply #11 on: January 18, 2015, 05:02:37 pm »
GPT fdisk (gdisk) version 0.8.8
Partition table scan:
  MBR: protective
  BSD: not present
  APM: not present
  GPT: present
Found valid GPT with protective MBR; using GPT.
Disk /dev/sda: 1953525168 sectors, 931.5 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): 119F1DC3-0358-4274-A1EA-7C251A4003DF
Partition table holds up to 128 entries
First usable sector is 34, last usable sector is 1953525134
Partitions will be aligned on 2048-sector boundaries
Total free space is 3437 sectors (1.7 MiB)
Number  Start (sector)    End (sector)  Size       Code  Name
   1            2048          206847   100.0 MiB   EF00  EFI system partition
   2          206848         2050047   900.0 MiB   2700  Basic data partition
   3         2050048         2312191   128.0 MiB   0C01  Microsoft reserved part
   4         2312192       782796799   372.2 GiB   0700  Basic data partition
   5       782796800       783718399   450.0 MiB   2700
   6       783718400      1911560191   537.8 GiB   0700  Basic data partition
   7      1911560192      1953523711   20.0 GiB    2700  Basic data partition
« Reply #12 on: January 18, 2015, 05:25:30 pm »
OK, I'm lost as to where Peppermint went  :-\
I take it you selected "Something Else" at the partitioning section of the installer ?
What is the goal here ? .. to resize the NTFS partition on the passport then install Peppermint to it, installing the bootloader to the external drives MBR (so the external HDD is bootable on other PC's and so the Linux bootloader doesn't overwrite the Windows one, breaking Windows) ?
If so, how much room do you want to allocate to Peppermint on the passport ?
is this a laptop or a desktop ? .. are you able to disconnect the internal HDD whilst installing Peppermint (for safety sake) ?
Offline silver2049
« Reply #13 on: January 18, 2015, 05:32:55 pm »
Yeah I selected, "Something Else" for the partitoning section.
In the partitioning section, what I did was allocate 100 GB for the swap space (because I thought I could put as much as I wanted), and the rest went to hard drive space, and I only chose installing the bootloader on the HDD because I thought that's what I was supposed to do.
And this is a laptop.
« Reply #14 on: January 18, 2015, 05:43:53 pm »
How are you able to boot Windows ?
I'm assuming either
a) the bootloader didn't get written to the Windows MBR because it's protected
or
b) you chose to install GRUB to the MBR of the external HDD .. and choose which HDD to boot from with the BIOS or boot device selection screen ?
Can you explain exactly what you have to do to get the flashing GRUB prompt ?
And what you have to do to boot Windows ?
« Last Edit: January 18, 2015, 05:45:25 pm by PCNetSpec »
