Author Topic: Installing from LiveUSB  (Read 3035 times)
Offline jack444
« on: September 20, 2014, 01:39:30 pm »
I created a Peppermint live USB using UNetBootin.
Selecting either 'Try live', or, 'Install', I get the same error message:
(initramfs) stdin: not a typewriter
mount: mounting /dev/loop0 on //filesystem.squashfs failed: invalid argument
can not mount /dev/loop0 (/cdrom/casper/filesystem.squashfs) on //filesystem.squashfs
Been googling this with no luck so far.
Thank you!
Re: Installing from LiveUSB
« Reply #1 on: September 20, 2014, 02:25:50 pm »
Have you checked the ISO's MD5 checksum ?
and have you tried using a different USB stick and/or USB creator app ?
How much RAM does your system have ?
Offline jack444
« Reply #2 on: September 20, 2014, 05:00:33 pm »
yes, it matches
yes, first I tried "USB Image Writer" that comes with Linux Mint, then UNetBootin -- same result each time
My laptop that I want to put Peppermint on has 4GB RAM.
Any chance that setting persistent memory on the live USB creation at 3GB would create an issue? The USB key is 16GB
Thanks!
« Reply #3 on: January 25, 2015, 05:42:41 am »
Which OS are you creating the LiveUSB in ?
