Author Topic: Wallpaper changer code  (Read 5780 times)
Offline rjm65
Re: Wallpaper changer code
« Reply #15 on: March 30, 2014, 07:01:46 am »
This is the question I asked over on linux mint forum that they never replied too...
Would be so nice if they had a script for cinnamon like peppermint has....  :)
Robert
Peppermint 9 User
Gateway Solo 9300 Pro
IBM T40
« Reply #16 on: March 30, 2014, 07:19:16 am »
Actually you can remove the "NUMBER" line from that script .. it's unnecessary.
It only needs to read:
#!/bin/bash
## Auto Wallpaper Changer
n=10
while [ $n -le 10 ]
do
sleep 30m &&
pcmanfm -w "$(find /home/YOUR_USERNAME/Pictures -type f | shuf -n1)"
done
Offline rmcellig
« Reply #17 on: March 30, 2014, 08:17:11 am »
Thanks!! I'm doing my jazz radio show at the moment but I had another question. Because I use Gnome-Schedule, how would I call the script using GS?
« Reply #18 on: March 30, 2014, 08:43:53 am »
I don't know anything about gnome-schedule
But my guess would be either
a) you'd remove the "while loop" and "sleep" from the script, then get gnome-schedule to run the script on you chosen schedule.
or
b) remove the script altogether, and just get gnome schedule to run:
pcmanfm -w "$(find /home/YOUR_USERNAME/Pictures -type f | shuf -n1)"on your chosen schedule
Offline rmcellig
« Reply #19 on: March 30, 2014, 01:23:50 pm »
Thanks for the one line solution. I will try it out. This is what I was looking for. So simple. I'll post back if this works or not. Thanks again!!!!!
