Author Topic: Peppermint 5 - Reset bottom panel to defaults  (Read 6404 times)
« on: September 16, 2014, 10:42:59 am »
The panel settings for each user are contained in the file
~/.config/lxpanel/Peppermint/panels/panel
So to put the bottom panel back to defaults, run:
gedit ~/.config/lxpanel/Peppermint/panels/paneland make the file read:-
# lxpanel <profile> config file. Manually editing is not recommended.
# Use preference dialog in lxpanel to adjust config when you can.
Global {
    edge=bottom
    allign=left
    margin=0
    widthtype=percent
    width=100
    height=22
    transparent=0
    tintcolor=#000000
    alpha=35
    autohide=0
    heightwhenhidden=2
    setdocktype=1
    setpartialstrut=1
    usefontcolor=1
    fontsize=10
    fontcolor=#222222
    usefontsize=0
    background=1
    backgroundfile=/usr/share/peppermint/images/panel-background.png
    iconsize=22
    loglevel=2
Plugin {
    type = menu
    Config {
        image=/usr/share/peppermint/images/menu-four.png
        tintcolor=#000000
        system {
        separator {
        item {
            name=Chromium
            image=chromium-browser
            action=chromium-browser
        item {
            name=Software Manager
            image=/usr/lib/linuxmint/mintInstall/icon.svg
            action=gksu mintinstall
        item {
            name=File Manager
            image=system-file-manager
            action=pcmanfm
        item {
            image=system-run
            command=run
        separator {
        item {
            image=gnome-logout
            command=logout
Plugin {
    type = space
    Config {
        Size=4
Plugin {
    type = taskbar
    expand=1
    Config {
        tooltips=1
        IconsOnly=0
        ShowAllDesks=0
        UseMouseWheel=1
        UseUrgencyHint=1
        FlatButton=0
        MaxTaskWidth=150
        spacing=1
        GroupedTasks=0
Plugin {
    type = pager
Plugin {
    type = tray
Plugin {
    type = volumealsa
Plugin {
    type = dclock
    Config {
        ClockFmt=%R
        TooltipFmt=%A %x
        BoldFont=0
        IconOnly=0
        CenterText=0
Plugin {
    type = launchbar
    Config {
        Button {
            id=peppermint-logout.desktop
SAVE the file, and log off/on (or reboot).
For reference there's a backup of the file at:-
/usr/share/lxpanel/profile/Peppermint/panels/panel
DO NOT delete/move/or edit this file .. I'm only mentioning it for reference.
