Author Topic: HP laptop webcam  (Read 399 times)
Offline Steve M
  • New To PeppermintOS
HP laptop webcam
« on: October 15, 2020, 01:46:39 pm »
My laptop camera seems to work OK. I tried to join a couple of different online meets. One on Google and the other via Jitsi. Both times it all connected OK but the sound was choppy. The second time I managed to turn off the mic permission which made the sound better so I could hear - but then I couldn't speak and couldn't find how to get the mic back.
When I test the camera offline it all seems OK.
This is the spec.
https://support.hp.com/gb-en/document/c06078882
Any ideas?
Offline rayzer
  • Graphics n Stuff
Re: HP laptop webcam
« Reply #1 on: October 15, 2020, 03:05:50 pm »
ive had that too, either the laptop or the connection isnt fast enough. disabling the camera is the easiest option because then the sound should at least work. use a wired connection when possible.
Offline Steve M
« Reply #2 on: October 19, 2020, 05:12:40 pm »
Interesting - thanks.
I've got new internet in between so the second time I was on fibre broadband.
I'm using the laptop because it has the camera. I could have used the desktop which is plugged in with ethernet cable. But then there's no camera!
HP has some tools that can check/fix? hardware issues, but it is all Windows10 based.
« Reply #3 on: November 20, 2020, 12:57:14 pm »
You might try opening Audacity and checking your mic settings for the best results.
