Author Topic: Sticky Keys, Bounce Keys, Slow Keys Erroniously Enabled at Boot Up.  (Read 202 times)
Offline plumtreed
  • Been using Peppermint since it's start-up
  • Peppermint version(s): 10 64bit
Just as Peppermint boots, I often get a small notification window that warns me that 'Sticky keys are enabled'.....the notification alarm often varies and I may be advised otherwise that 'Slow keys' or 'Bounce keys' are enabled????
Running a search suggests running 'xfce4-accessibility-settings' and 'unticking' where necessary but there was nothing to untick!
I am not sure if this problem actually affects my keyboard but I don't find any difficulty in normal use.
Is there a way to effectively avoid these random messages and more importantly avoid having issues with my keyboard?
