Author Topic: sudo apt-get upgrade triggers syntax error - RESOLVED  (Read 467 times)
Offline rkkc
« on: September 24, 2020, 12:12:30 pm »
Hello!
I have run into a problem that has really thrown me for a loop.
When I install applications via the software manager and the command line I get this error:
It looks like something is wrong with the mint-adjust.py python file...but I can't figure it out for the life of me.  After reviewing the file, it looks like it might be a difference between python 2 and 3, but update-alternatives only shows python 3.6 as registered...  Honestly, I'm in over my head on this one.  I could just leave it and deal with the error.  Applications still install, it's just the final logging that messes up, but I want it to be right, not just working.
Thanks for any assistance!
« Last Edit: September 26, 2020, 07:24:49 am by rkkc »
Offline invisible
  • Peppermint & Ubuntu
Re: sudo apt-get upgrade triggers syntax error
« Reply #1 on: September 25, 2020, 02:49:24 am »
I think that the clue is in the error message - invalid syntax.
  File "/usr/lib/linuxmint/mintSystem/mint-adjust.py", line 173
    except Exception,detail:
I had a look at line 173 in the same file on my Peppermint 10 and there is a space missing after Exception,
except Exception, detail:
sudo nano /usr/lib/linuxmint/mintSystem/mint-adjust.pyNavigate to line 173 and add the space
Save the file and see if you get the same error.
« Last Edit: September 25, 2020, 02:52:28 am by invisible »
Offline rkkc
« Reply #2 on: September 25, 2020, 05:02:35 pm »
I did check that out last night, just made the change now again and the same error came up except now it has a space.   :(
SyntaxError: invalid syntax
dpkg: error processing package peppermint-system (--configure):
 installed peppermint-system package post-installation script subprocess returned error exit status 1
 peppermint-system
E: Sub-process /usr/bin/dpkg returned an error code (1)
Offline invisible
« Reply #3 on: September 26, 2020, 12:48:17 am »
Try this in an internet search.
Quite a few replies to peruse (including some from Peppermint forums)
Possibly, it is a case of removing and purging the offending package and then re-installing.
However, please tread carefully with system packages and please make sure you have back-ups.
Offline rkkc
« Reply #4 on: September 26, 2020, 07:07:00 am »
I followed a guide on removing peppermint-system and purging related files.  I did NOT restart prior to reinstalling and it is throwing the same error.  I'm fairly convinced it has something to do with the python code in mint-adjust.py...  I just tried two things:
sudo python2 /usr/lib/linuxmint/mintSystem/mint-adjust.pyReturns nothing
sudo python /usr/lib/linuxmint/mintSystem/mint-adjust.pyReturns the error:
Offline rkkc
« Reply #5 on: September 26, 2020, 07:22:53 am »
GOT IT!   :D
It was the python interpreter.  Installed it in update alternatives and changed python to default to python2.
sudo update-alternatives --install /usr/bin/python python /usr/bin/python2 1
sudo update-alternatives --config python
Feel a little dumb, but I'm glad I went through this and didn't give up or just reinstall.  :)  Honestly, this is one thing I love about Linux.  You break it, you fix it, you learn along the way.  WOO!
Thank you all for assisting!
Offline straybit
  • New To PeppermintOS
    • Middleton Post 39
Re: sudo apt-get upgrade triggers syntax error - RESOLVED
« Reply #6 on: September 26, 2020, 07:28:30 am »
I was going to suggest that the caret was pointing to what looked like a comma to my aged eyes and perhaps it should have been a period.
Glad you got it resolved anyway.
Bruce
Offline VinDSL
« Reply #7 on: September 26, 2020, 10:11:50 am »
Good job, Detective rkkc!   :)
