Author Topic: Can't install on HP Laptop  (Read 1126 times)
Offline MrGizmo
  • Peppermint version(s): 9 & 10
« on: August 17, 2020, 10:11:45 pm »
I'm trying to install Peppermint on an HP 15-dw2063st and as soon as I choose something from the menu, the screen goes blank. I have tried these installers:
Peppermint 9, 32 bit
Peppermint 9, 64 bit
Peppermint 10, 32 bit
Peppermint 10, 64 bit
I even tried Xubuntu 18.04 64 bit, all with the same problem. I also tried nomodeset at boot time but no joy. This is the first computer I have seen that I can't install Linux on. Any suggestions?
Thanks,
Chuck
UPDATE:
I was able to boot Ubuntu Mate 16.04.1. Here is the output from inxi:
System:    Host: ubuntu-mate Kernel: 4.4.0-31-generic x86_64 (64 bit)
           Desktop: MATE 1.12.1  Distro: Ubuntu 16.04 xenial
Machine:   System: HP product: HP Laptop 15-dw2xxx v: Type1ProductConfigId
           Mobo: HP model: 85F3 v: 40.23 Bios: Insyde v: F.02 date: 05/18/2020
CPU:       Dual core Intel Core i3-1005G1 (-HT-MCP-) cache: 4096 KB
           clock speeds: max: 1201 MHz 1: 400 MHz 2: 400 MHz 3: 400 MHz
           4: 400 MHz
Graphics:  Card: Intel Device 8a56
           Display Server: X.Org 1.18.3 drivers: fbdev,intel (unloaded: vesa)
           Resolution: 1366x768@76.00hz
           GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 3.8, 256 bits)
           GLX Version: 3.0 Mesa 11.2.0
Audio:     Card Intel Device 34c8 Sound: ALSA v: k4.4.0-31-generic
Network:   Card-1: Intel Device 34f0
           IF: N/A state: N/A speed: N/A duplex: N/A mac: N/A
           Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169
Drives:    HDD Total Size: 128.0GB (21.2% used)
           ID-1: /dev/sda model: SSSTC_CV8 size: 128.0GB
Partition: ID-1: / size: 3.8G used: 20M (1%) fs: overlay dev: N/A
Sensors:   None detected - is lm-sensors installed and configured?
Info:      Processes: 182 Uptime: 12 min Memory: 436.8/7766.3MB
« Last Edit: August 19, 2020, 01:20:14 pm by MrGizmo »
Re: Can't install on HP Laptop
« Reply #1 on: August 18, 2020, 07:29:38 am »
edit: you could try installing on another PC to a USB partition and then copying that partition to the HP and installing GRUB. That's about all I can think of at the moment.
Offline MrGizmo
« Reply #2 on: August 18, 2020, 09:13:09 am »
I thought of that too, but if the video drivers are incorrect then the display won't work then either. I'm not sure I can install grub either since I can't make the live CD work. I've tried booting from a USB connected disk that has 9 & 10 on it already but it won't boot.
Thanks for the suggestion.
So here is another question: Is it possible to install the Peppermint DE over an Ubuntu Mate installation?
« Last Edit: August 18, 2020, 09:51:58 am by MrGizmo »
« Reply #3 on: August 18, 2020, 12:56:20 pm »
Hi MrGizmo, are you able to get into your bios and check/change settings in there?
Offline MrGizmo
« Reply #4 on: August 18, 2020, 10:46:30 pm »
I looked at the bios and reset it. I don't think that can explain why Ubuntu Mate works. I think it must be video drivers. It seems like Peppermint can't work with the "Intel Device 8a56" video.
Ubuntu Mate 20 works correctly. Perhaps one of the maintainers could see what video drivers are used there.
« Last Edit: August 19, 2020, 01:21:52 pm by MrGizmo »
Offline invisible
  • Peppermint & Ubuntu
« Reply #5 on: September 23, 2020, 10:12:09 am »
Is this laptop a recent model?
Usually Intel graphic drivers are included in the kernel.
This would offer an explanation why Peppermint 10 and earlier did not work, yet Ubuntu mate 20.04 with kernel 5.4 was OK.
However, you mentioned that Ubuntu Mate 16.04 also booted OK - a bit of a mystery being 4 years old.
Anyway, according to this info, you need the 5.3 kernel or newer.
https://askubuntu.com/questions/1199944/dell-inspiron-3593-shows-display-unclaimed-for-intel-device-8a56-rev-07
« Reply #6 on: September 29, 2020, 04:14:03 pm »
Is your hard drive file system mbr or gpt?
« Reply #7 on: October 03, 2020, 07:57:16 am »
Another thing, how big is the partition you are trying to install into?
