Author Topic: Synaptic Package Manager asks for password SOLVED  (Read 1571 times)
Offline KEP3
« on: July 30, 2020, 08:39:28 pm »
I want to run the update manager but synaptic keeps asking for a password. I entered the system password  but no go, Joe. How does one change the password or otherwise get rid of it?
« Last Edit: August 23, 2020, 11:27:45 am by KEP3 »
Re: Synaptic Package Manager asks for password
« Reply #1 on: July 31, 2020, 02:59:42 am »
Hi KEP3,
Two questions:
1.) Do you require a password to login to the desktop?
2.) Have you at some time created a superuser (admin) account?
Looking at your previous posts in this forum I noticed that you have had problems with your password several times in the past. In particular, the issue in your last posts before this thread (from Feb. 24 & 25, 2020) was apparently never resolved -- or at least you never indicated that it had been resolved. And, if it had been resolved, you never indicated how you managed to resolve it. Not knowing these things makes it very difficult for us to assist you because your previous actions might have resulted in changes to your system that we need to know about in order to intelligently assist you with your current issue. This is why users should always mark their issues as (SOLVED) when the issues have been solved, and also indicate the steps they made to solve the issue.  ;)
« Last Edit: July 31, 2020, 03:24:04 am by Slim.Fatz »
Offline KEP3
« Reply #2 on: August 02, 2020, 11:22:30 am »
Sorry about not posting as resolved. Completely forgot. Yes, the other password problem was resolved.
No, I do not have a password to the desktop. I do have to jump thru hoops on my HP laptop to get to Peppermint. On my desktop I just selected the OS at startup.
No, I have not set up a superuser / admin account.
Next?
« Reply #3 on: August 02, 2020, 01:09:23 pm »
Hi KEP3,
Since you are not required to enter a password to login to the desktop & you have never set up an extra superuser/admin account, could it be that what you think is the system password actually is not the system password?  :-\
You can check this by doing the following: open a terminal and enter
sudo gedit /etc/fstab
This will ask for your (system) password. If what you enter results in the text editor opening the fstab file then your (system) password is correct (do not change this file in any way if it opens -- just close the editor).
« Reply #4 on: August 05, 2020, 10:52:02 pm »
Keep in mind, KEP3, that when you are asked for a password in the previous command, you will not "see" what you are typing, just type in your password and hit enter.
Offline KEP3
« Reply #5 on: August 23, 2020, 11:17:26 am »
Well, when I open recovery mode the password I enter gets me in. When I try the same password to run the update manager I get nothing. I'm so confused.  :-\
Offline KEP3
« Reply #6 on: August 23, 2020, 11:25:09 am »
 :'( It really helps to type in the correct letters when working from recovery mode. Once I did that I got everything copacetic. And I also wrote down the password. Now if I could only remember where I put the piece of paper... :D :D
And where did I put that resolved button??
Re: Synaptic Package Manager asks for password SOLVED
« Reply #7 on: August 24, 2020, 12:41:09 am »
Hi KEP3,
Oops! Been there, done that too!!  :P It's one reason I like for my keyboard to have an LED that indicates when the caps-lock key has been pressed  :D
Thanks for marking the thread (SOLVED)8)
