Author Topic: revisiting: I forgot my password. (SOLVED)  (Read 845 times)
« on: July 30, 2020, 02:09:33 pm »
Sometimes, even us old timers, long time users of peppermint os still run up against bafflement.
Several weeks ago, my main install of PMX Respin on my desktop began not allowing me to login. Being distracted with other things, I simply turned it off and let it sit.
https://forum.peppermintos.com/index.php/topic,8951.msg91197.html#msg91197
I have run thru all the lost password tutorials, but I can't get past the login screen. Thing is, I never forgot my password. I know what it is, and the root shell prompt accepts it while I am in the process of changing it to something else.
but the stupid login screen will not budge, nor am I allowed to use the guest login.
While I know it might be quicker to 'just reinstall PMX" ... I prefer not to, as I have 30 some ICE SSBs which are a pain to recreate.
 :o
« Last Edit: August 10, 2020, 11:53:04 am by spence »
& '18 Asus VivoBook
Offline VinDSL
Re: revisiting: I forgot my password.
« Reply #1 on: July 30, 2020, 02:18:00 pm »
Maybe, something like this: https://is.gd/Eilz2c   :-\
« Reply #2 on: July 30, 2020, 04:32:17 pm »
Sorta the same procedure as the prior link... doesn't work...  :-X
and I learned it's NOT letting me change the login password... only the old original one works... you know, the one i didn't forget but that damn login screen that I never enabled won't let me pass thru.
« Last Edit: August 10, 2020, 11:53:24 am by spence »
& '18 Asus VivoBook
« Reply #3 on: August 01, 2020, 09:03:20 am »
That can happen if your / partition fills up. Check that there's free space and then do an upgrade.
« Reply #4 on: August 10, 2020, 11:22:09 am »
left the machine unplugged since my last post... fired it up a few minutes ago and still can't login to PMX...   >:(  rebooted into PMIX.
hmmm, partition too full? that 17 gb partition sits at 77.1% occupied   :-\
« Last Edit: August 10, 2020, 11:23:42 am by spence »
& '18 Asus VivoBook
« Reply #5 on: August 10, 2020, 11:52:13 am »
Hooooo... rraaaayyyyy!    :D
While I was mentally prepared to do a complete reinstall today, I decided to double the size of my PMX partition first! Rebooted into PMX Respin successfully... thanks for that tip
@murraymint !!!
« Last Edit: August 10, 2020, 11:55:53 am by spence »
& '18 Asus VivoBook
Offline VinDSL
Re: revisiting: I forgot my password. (SOLVED)
« Reply #6 on: August 10, 2020, 11:57:04 am »
B00M!!!   :)
