Author Topic: When does the next version of Peppermint release?  (Read 25455 times)
Offline kendall
  • Co-Founder
« on: March 12, 2014, 04:37:53 pm »
At Peppermint, we don't adhere to a strict release schedule as many other distros do. Rather we adopt a policy of "it's ready when it's ready." Of course we don't try to delay the release any longer than is absolutely necessary, but sometimes it comes a little faster and sometimes it comes a little slower. Being that Peppermint is based on the April release of Ubuntu each year, we typically release during May or June.
Offline Chris
  • Peppermint version(s): 4
Re: When does the next version of Peppermint release?
« Reply #1 on: August 08, 2014, 12:20:26 pm »
Until when Peppermint 4 is getting updates?
Offline rjm65
« Reply #2 on: August 08, 2014, 12:27:23 pm »
Peppermint 4 is no longer getting updates it is quite dead in the water right now.
Robert
Peppermint 9 User
Gateway Solo 9300 Pro
IBM T40
« Reply #3 on: August 08, 2014, 01:52:54 pm »
Hi Chris, Its as the guys have said, Peppermint OS Four has been unsupported since April 2014.  Ubuntu have finally shut down all the servers.  I noticed that you have been running Peppermint OS Four 32bit.  Your computer is a 64bit machine.  Peppermint Five 64bit should easily install.  The big bonus is, it is based on Ubuntu 14.04 LTS.  This effectively gives Peppermint Five, five years of support, (April 2019).   I can honestly say Peppermint Five is a huge improvement to Peppermint OS Four.  We both know how good it was too  8).  That says a lot about Peppermint Five.  Good luck!
Offline nomko
  • Linux User
    • Easy tips for Linux
« Reply #4 on: November 20, 2014, 05:42:53 am »
As far as i understood this, Lubuntu 14.04 LTS will get 3-years support instead of the full 5-year support:
From Wikipedia.org:
14.04 LTS   Trusty Tahr   2014-04-17   April 2017   Long-term support release, supported for 3 years
I've read somewhere else that the 3-year support only applies for Lubuntu specific software and that Lubuntu will get (Ubuntu) security updates for 5 years... Not sure is this is true.
ASUS P5KPL-AM*Intel Core2 Quad CPU Q8200*4 GiB ram*nVidia GeForce 9500GT*Realtek RTL8101/8102E*Optiarc DVD-RW AD-7200A*HDD:Samsung HD501LJ/HD103SI*Sitecom X5-N600 Router
My Linux website
« Reply #5 on: November 20, 2014, 08:04:42 am »
OK, the lowdown....
The Peppermint specific stuff will receive updates only until Peppermint 6 .. so 1 year
Lubuntu specific software (the LXDE bits) will receive updates for 3 years
All the other stuff, 5 years
Now think about it .. The peppermint specific stuff tends to be configuration, artwork, and a couple of apps that are unlikey to change much anyway (peppermint-control-center / ice) .. any bugs are usually well sorted by the time a year is up.
LXDE is dropping the gtk stuff anyway
99% of the OS is directly from the Ubuntu (14.04) repos
So .. 99% of Peppermint 5 will be fully supported for 5 years .. the other stuff is unlikely to need any updates during that extended period = Peppermint though not "officially" an LTS can be treated as one, and should be good for 5 years.
(that said, you can always move to the next version if you choose)
Offline nomko
  • Linux User
« Reply #6 on: November 20, 2014, 09:49:27 am »
Thanks for the info!
My Linux website
Offline Mynaardt
« Reply #7 on: March 25, 2015, 01:44:12 pm »
Hello!
I know I've not posted on the PMOS form (much).  But I really do like PMOS; it's very nice for my older computers.
Anyway, when the new release comes out; how does one upgrade?
Is it the Ubuntu method of a long update process that leaves your data where it is?  Or the LInux Mint method of starting from scratch (including a data back up utility, of course)?
Just wondering how an upgrade might be, typically.  I've got Peppermint 5 on two computers (a laptop and netbook), and will be installing it on a slightly-larger-than normal netbook.  They're all old workhorses that work just find with Linux.  And I figure PMOS is perfect for all of them, since I typically take them to libraries or coffee shops or the like to make use of free WiFi.
Thanks!
~*~  Mynaardt  ~*~
(Victoria, BC, Canada)
Peppermint OS is your computer's friend,
Always Trust Peppermint OS!
« Reply #8 on: March 25, 2015, 02:49:06 pm »
Peppermint historically release around May/June annually .. and the update method is like Mint (full reinstall).
Offline Mynaardt
« Reply #9 on: March 25, 2015, 02:58:52 pm »
Thanks for that.  Just wanted to know what was in store for me when Peppermint six comes out!
Are there instructions for that specific to Peppermint, or should I just look at the Linux Mint instructions?
« Last Edit: March 25, 2015, 03:00:24 pm by Mynaardt »
~*~  Mynaardt  ~*~
« Reply #10 on: March 25, 2015, 06:02:53 pm »
I don't think that you need to worry about this already: it will be several years until Peppermint 6 is available ...  ::)
Offline Mynaardt
« Reply #11 on: March 25, 2015, 06:50:17 pm »
Better Safe than sorry!   8)
~*~  Mynaardt  ~*~
Offline sanguinemoon
  • Peppermint version(s): 6
« Reply #12 on: March 26, 2015, 02:52:03 am »
Just enough to time for me to break this installation so I can get a fresh one ;)
« Reply #13 on: March 26, 2015, 09:41:35 am »
LOL :))
Offline DrCreamcake
  • Peppermint version(s): version5 and version 3
« Reply #14 on: March 29, 2015, 02:16:54 pm »
Hello Folks thanks for the update I wonder if the Peppermint team may look at moving to LXQT for Peppermint 6 sounds like a logical route or XFCE thanks
OK, the lowdown....
